How do I fix a 5100 printer error on a PIXMA MX432?
Karalou
I need to fix a 5100 error code on my PIXMA MX 432 printer.  I had a paper jam which I removed by opening the underside of  the printer.  I then found a 5100 error when I turned the printer back on.  Help!
2 REPLIES 2
surf579
where is the little latch for the 5100 jam   do you have a pic of it  I would appreciate it or suggestion . Because a few other printers have same thing a fixed but i have MX420 and see nothing like that  thank you , Surf579
Check out THIS article. It should help. 😊
