01-26-2014 06:29 AM
I can't figure out how to print on legal size paper . . . how is this done ? The paper tray only holds 8 1/2 x 11.
02-08-2014 03:11 PM
Hi, William! I don't know if you've found the answer to your question, but I've been wondering the same thing! On the few occasions I've needed to print on legal-size paper, I've just pulled out the lower papertray, put a sheet or two of legal in on top of the letter-size sheets and closed the tray with a "paper tail" sticking out. It seems ridiculous but it works. However, after seeing your post I pulled the paper tray out, removed the paper and inspected the tray more closely. Lo and behold! - with the paper out, if you look inside the tray to the left, you'll see a "depressable" plastic button adjacent to an arrow with an "LGL" label. It takes a little slight-of-hand, but if you press down on that button and pull at the front of the tray, it slides out into a new locked position -- expanding the extra 3" needed for legal paper and revealing a new "LGL" detent for the paper length adjuster! I'm sure the Canon engineers thought this would be totally obvious to the user but I've owned several Canon printers now and this is the first time, like you, I've been stumped to figure out how to use legal-size. Thanks for posting on the forum so I'd see your question, get motivated by it and finally find the answer to what's been bugging me, too! By the way, Canon, the MX922 is a really great printer! I get wonderful results whether printing photos, web pages or work docs. Really affordable to boot!
01-02-2015 06:13 PM
If you pull out the lower cassette, on the left hand side nearest you there is a picture of an envelope and a sheet of paper sort of curled up. Above that is a rectangular button and an arrow pointing towards you daying "LGL". If you push the button down you can pull out the front part of the cassette to alloy you to load legal-size paper without it sticking out from the cassette. There are more instructions for prining on odd-size paper in the file "MX920ser_ReadMeFirst_EN.pdf"
01-26-2014 08:49 AM
Hi williampeck1958!
To have a better understanding of your issue, please let everyone know what operating system (Windows XP/Vista/7/8 or OS 10.X) you are using. That way, community will be able to assist you with suggestions appropriate for your product.
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks!
01-26-2014 08:58 AM
Windows 7 Enterprise.
But the OS has nothing to do with - where do I put the legal size paper ? It doesn't fit in the tray.
But thanks !
02-08-2014 03:11 PM
02-08-2014 05:48 PM
timdugas,
whoa, that's pretty sweet ! but I wonder why the Canon rep (two replies above yours) didn't answer that . . . she wanted to know what was my operating system . . . LOL
but that is great, thank you so much.
I do love the printer (and good value), but the wireless sucked to high heaven, it only worked with a direct USB connection. See all the laments here.
02-19-2014 12:13 PM
04-01-2014 09:51 PM
04-01-2014 10:21 PM
yes, it was interesting and kind of funny. I don't know why they asked for the OS . . .
05-02-2014 04:17 PM
I have the same problem when airprinting from my Garmin Pilot app, which does not provide settings for paper size. The printer thinks the document is a photo size (too small to use), and gives the out of paper error. Can the printer be forced to print 8.5x11 regardless of what is coming to it? Thanks.
05-26-2014 03:45 AM
Hi NewCanonUser,
When printing using Apple AirPrint, the paper size is selected automatically according to the application software being used on the Apple device and the region in which AirPrint is used. If there is not a selectable paper option in the app you are printing from, you will need to print from the paper tray that is automatically selected.
More information on printing via Apple AirPrint can be found here.
