07-19-2015 12:18 AM
My Pixma MG7120 Printer is printing all black text in blurry fashion. I have cleaned in every way and even replaced the black ink. Not sure what I am doing wrong or how to fix.
01-15-2024 12:29 PM
That certainly improves it Mike for text in a letter, but PGBK check pattern still blurry
03-11-2024 08:02 AM
Hi, In this photo, please can you explain what is item A and item B? I'm guessing one of them is the Encoder film?
06-17-2024 07:34 AM
Similar alternative work-around iP7250 - select Borderless printing, then you can re-select plain paper. Either way, I think black is generated from the colours, rather than the dedicated black print tank. My "blurriness" shows up as (when very fine) vertical black lines seperating and merging over about 30 mm into two about 1/2 mm apart. Alignment, cleaning, etc has no effect.
10-08-2024 03:27 PM
I have been unable to do this on my PIXMA 920. Is it worth bringing to a repair shop? Maybe they can do it? Please reply!
