G6020 Firmware Update Failed
danjody
I got a message this morning saying that there was a new firmware version available on the server.  I used the menus to apply it.  The update failed and it told me to hit the "on" button.  I did so, and now the LED just blinks and none of the buttons do anything.
5 REPLIES 5
ryandmonk
I also experienced a similar issue with the firmware update for printer model G6020 on 02-12-2023. After acknowledging to start the update on the printer screen, it shortly started flashing with error code 6800. Unplugging the power cable for several minutes to reset it, as the manual and other posts recommend, does not work.
After calling Canon support, it was indicated that performing the firmware update caused a hardware issue, and the printer will need to be replaced since it is out of warranty. My recommendation for others is if your G6020 works fine, please don't apply the update.
ps_canon
I had the same problem today.
1.Tried to install the uodate using the printer control panel
2. Watched the download and install process
3. Got message  "Update failed .Press [ON] to continue."
4. Pressed the power switch, waited 5 minutes with nothing happening.
5. Press the Power button again, waited another minute
6. Shut off power at the  surge protector and waited 1 minute.
7. Turned on surge protector and pressed printer's power button.
8. Waited 5 minutes and saw "Downloading" on the status panel.
9. Waited another 5 minutes and saw the downloading progress asterisks.
10. When the progress bar was completed, the panel blanked and the printer restarted itself, Displaying "Canon" and then the copy menu.
It seems to work ok now, but what a PITA. .
Same issue, this solution worked for me as well. Thank you!
birdofprey
For record: I just had the same problem with Canon Pixma G6050, updating its firmware from v1.05 to v1.07. The workaround above worked fine for me: after disconnecting the power cord, waiting till the power light stops blinking, and then reconnecting the power cord, the update download & installation resumed and successfully completed shortly.
