12-17-2018 06:54 PM
I recently purchased the G4210 to handle all my wedding seating cards, set it up with what I thought was no problem - but it prints blanks! No error message, runs the paper thru, etc. Anyone else have this issue? HELP!
12-19-2018 02:15 PM
I just called Customer Care and spoke Daniel who was AWESOME! He walked me through trouble shooting and it's now printing !!!!! Thank you 🙂
12-19-2018 09:11 AM
Hi dlenam,
I recommend performing a nozzle check first. Please click HERE for the steps to print the nozzle check. Once the nozzle check prints, please click the link in step 6 to compare you nozzle check.
If the nozzle check from your G4210 does not look like the sample nozzle check, please click HERE for the steps to perform a nozzle cleaning.
If the nozzle check prints correctly, please try to make a copy directly from the printer. This will help narrow down if there is a hardware or software issue.
12-19-2018 01:25 PM
I performed the Nozzle Check and the paper came through blank. Same problem.
12-19-2018 01:32 PM
Hi dlenam,
I recommend performing a deep nozzle cleaning. Please click HERE for the steps.
If the printer still does not apply ink to the paper, the printer may require service. Please call us at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST so we can look into your service options.
12-19-2018 02:15 PM
02-23-2020 09:09 PM
Just in case this might help someone. I have tried numerous troubleshooting efforts on my Canon G4210 this weekend. I use a mac laptop so here's a run down of what I have tried with no results.
I tried resetting my mac's printing system. Didn't help. I tried resetting my router. Didn't help. I tried using the disk utility first aid. Didn't help. I tried calling Canon. No answer, but I'll try again tomorrow. I tried using the copy mode to scan a document to see if it would print. Didn't help. I tried printing from my other mac. Didn't help. I'm a senior / not tech savvy but I did everything I could think of and nothing has helped me. I did do a nozzle check and it came out perfectly. But nothing else prints on the paper. Just spits out blanks.
