Deleted Comment
LeoScott
On 7/27/2015 I posted a comment about the updated printer drivers for a Canon MX922 causing boot delays when the printer was not on when the computer booted.  Boot times went from a normal 20 seconds to over 2 minutes.  Instead of returning the next day to see replies, the comment was gone.  Canon, that was a very bad idea.  I have been doing computers since my first Apple II integer machine and involved in BBS, Forums and comment boards from the beginning.  Because of your actions I will now post that you delete honest comments that cast a bad light on Canon in every forum where they are pertinent. I will post the truth but will try to cost you sales.
1 REPLY 1
Moderator
Moderator
Hi, LeoScott!
Thanks for using the Canon Community Forums.  Your post was not deleted; instead, it was moved to the correct category as your MX922 falls under the category of "Printer/Multifunction Support."  You'll find your post right here.
We hope this helps!
