10-26-2013 01:02 PM
We use Google apps for nonprofits and all of our email is handled by gmail.
What settings do we use on the MF9220Cdn to send scans by email?
I have set the SMTP server, username & password. How can I turn on SSL?
Any help?
10-29-2013 05:21 PM
Hi ourcalling.
The imageCLASS MF9220Cn does not support SSL, therefore using a web-based email account, such as Gmail is not supported.
Should you need further assistance with setting up the machine over the network, please contact us at 1-800-OK-CANON (1-800-652-2666).
10-30-2013 12:36 AM
Gmail supports a non SSL connection. https://support.google.com/a/answer/176600?hl=en
Over 5 million businesses use Google Apps for business. Don't you think Canon should make their product work on Google apps?
06-15-2014 01:17 PM
Here's what I use in System Management Settings:
Network Settings
TCP/IP Settings
Port Number Settings
SMTP: 587
E-Mail Settings
SMTP Server Address: smtp.gmail.com
E-Mail Address: <<myusername>>@gmail.com
Authentication/Encryption Settings
Use POP Authentication Before Sending: Off
Use SMTP Authentication: On
User Name: <<myusername>>@gmail.com
Password: Set.
Use SSL: On
Confirm Certificate for SMTP Sending: Off
It took me a while to get this, and like the reply you got, Canon was no help at all when I asked them via email. Good luck!
10-08-2015 06:36 PM
04-10-2017 01:31 PM
a client of mine is having the same problem that he cannot enter a custom port for the scan to email communication. Can you explain where it was setup exactly and if it was done through the webinterface or the menu on the printer itself? Hope to hear soon from anyone that can help us out!
Regards,
Bram
The Netherlands
09-18-2017 08:57 PM
You can set the smtp port through the remote UI. Naviage to:
Settings/Registration: Preferences: Network Settings > Port Number Settings
Or you can go directly to:
http://<your printer address>/m_network_portnum.html
