04-28-2020 10:20 AM
I read somewhere that when you turn on your Selphie printer, the ink cartridge advances, thus wasting the cartridge.
But from what I remember there is something you do when you press the power button to prevent that from happening.
Does anyone know what that is?
Thanks in advance,
Rich
05-08-2020 08:08 AM
05-07-2020 02:26 PM
Hi rbaroncpd,
To make sure that the printer is using the proper color when it it starts to print, the printer will advance the ink roll to the beginning of the next set of colors. Unfortunately there would not be a way to bypass that function. The best way to use the printer so you do not waste any prints would be to try and print using the roll at once or to leave the printer on until you finish all of your printing.
05-08-2020 08:08 AM
Hector,
Thanks much for the reply.
