03-11-2021 03:36 PM
I have Canon MX920, I can print but scanning is no longer an option? I downloaded and installed the scanner driver already. This is a new computer, on my old computer I could scan with no problem. But now I can't seem to do it.
03-11-2021 03:44 PM
Hi, hleelee!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or Mac OS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
03-11-2021 03:49 PM
Mac OS Big Sure 11.2.3
04-05-2021 08:06 PM
I am on Big Sur 11.2.3. I am trying to scan wirelessly.
04-16-2021 01:39 PM
Hi hleelee,
Please follow these steps:
1. Click on the Apple in the upper left corner and then System Preferences.
2. Click on Printers & Scanners.
3. Click 1 time on the Canon MX920 and then [-] at the bottom.
4. Once removed, click the [+].
5. In the Add window, a Canon MX920 listing with "IJ Network" will appear. Click on that 1 time.
6. At the bottom, next to "Use", please select Canon MX920 series from the drop down box if it is not already selected.
7. Click Add.
Once the printer is reinstalled, please attempt to scan using the IJ Scan Utility.
https://ij.manual.canon/ij/webmanual/ScanUtility/M/MX920%20series/1.1/EN/SU/Top.html
04-16-2021 02:01 PM
So I did that and it still doesn't show up.
Previously this is what I saw:
Now this is what I see.
04-22-2021 01:55 PM
Hello,
Please try download and installing the two scanner files for the MX922 below. After the scanner drivers are installed, please remove and add the MX922 again.
misd-mac-ijscanner5-4_0_0-ea19_2.dmg
msd_-mac-mx920-19_2_0-ea11.dmg
If the scanner option does not appear like it did in your picture before, open the search finder on your mac and search for IJ Scan Utility. If you are able to open IJ Scan Utility, please try to scan. I see Patrick attached a link in his response about using IJ Scan Utility.
04-22-2021 01:57 PM
I installed both of those, and re-added the printer. Still doesn't show up.
I can open the IJ Scan Utility, but I'm not connect via USB. I need wireless scanning.
04-28-2021 01:25 PM
Hi hleelee,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below:
https://mycanon.usa.canon.com
05-30-2021 11:02 PM
I have this same issue with Big Sur and all the latest drivers from Canon. I just reinstalled them and removed and added the printers. Any help?
When adding a printer, it shows up as "Bonjour" rather than "Bonjour Multifunction" is that an Apple or Canon mistake?
