03-22-2019 10:38 PM - edited 03-22-2019 10:39 PM
So I just got a Canon MG 3620 and I'm trying to print up a small 5X7 8 page booklet. I'm using basic 8.5x11 paper and printing two 5x7 pages on one side and two more on the other - four pieces of paper all together. So my issue is I can't figure out how to get it to stop either printing everything back ward OR when it doesn't do that the pages will be upright on one side and turn it over and everything is upside down. I'm sure there is some simple setting I'm missing but the online manual doesn't seem to address it!
I've skimmed the forums and I've seen answers to this for other printers but I need one with this printers set up because they're similar but not the same. Any assistance would be greatly appreciated! I have a document I need to submit tomorrow and I can't figure this out.
P.S in case it makes any difference I've tried printing from both the InDesign document and from a PDF. Also I'm using a Mac.
03-23-2019 11:46 AM - edited 03-23-2019 11:48 AM
Seems your issue had a deadline... This is when you make a judement call and go to Kinkos.
Takes the pressue off and now you have the time to figure out why your booklet isn't printing as expected.
There is likely an "invert" checkbox. Unfortunately, printing from a MAC might have other limitations depending on the OS version and print driver being used.
03-23-2019 12:52 PM
03-29-2019 02:07 PM
Hi RainaJ,
Are you using page layout printing? Please click HERE for detailed information.
03-31-2019 01:24 PM
Yes, I was using layout and it still did that. 😞
04-01-2019 01:43 AM - edited 04-01-2019 01:44 AM
I had the same problem on a booklet. Change the binding side from long-side to short-side binding or vice-versa. It will change the expected direction of page turning. This is found under layout by the way.
