11-13-2013 11:24 PM
Okay so, I managed to stump Canon tier three support and they recommended I contact Microsoft support who refused to help without me paying them $99.
I have a Canon MX922 multifunction that worked flawlessly with Windows 8 however, after upgrading (with a clean install) to Windows 8.1, I can not get the drivers to fully install.
When running the install package (mast-win-mx920-1_0-ucd.exe) I get no errors however, the IJ Network Scanner Selector EX is not getting installed (this is needed to scan across the network). I extracted that install package (\mast-win-mx920-1_0-ucd.exe\mast-win-mx920-1_0-ucd\win\Driver\LANUTIL\SELECTOR\) from the main install package and tried to run it and received the following error: "An error occurred while files were being copied." and then the install fails.
Before calling Canon, I tried installing both the main install package as well as the IJ Network Scanner Selector EX package in a clean boot state and received the same results.
The only thing Canon could come up with was to copy 'usbscan.sys' to C:\, C:\Windows\System32\drivers and C:\Windows\System32\DriverStore\FileRepository and to try again.
Anyone have any ideas?
Below is the install log:
<2013/11/13 18:33:37>LANG:0409:0<2013/11/13 18:33:37>CHANGED:0409 <2013/11/13 18:33:37> MUI is:0409 <2013/11/13 18:33:37> FixedLang:English <2013/11/13 18:33:37> GetUserDefaultLangID:0409 <2013/11/13 18:33:37> RESIDENCE:america <2013/11/13 18:33:37> GetUserDefaultUILanguage:0409 <2013/11/13 18:33:37> GetSystemDefaultUILanguage:0409 <2013/11/13 18:33:37> GetSystemDefaultLangID:0409 <2013/11/13 18:33:37>INIT_PROC <2013/11/13 18:33:40>DotNet is 1 <2013/11/13 18:33:45>EXITCODE is 1 <2013/11/13 18:33:45>RESIDENCE_PROC <2013/11/13 18:33:45>ITEM_WinVista <2013/11/13 18:33:48>EULA_PROC <2013/11/13 18:33:48>EULA_INIT_ACTION <2013/11/13 18:33:50>CALL_LANDRIVER_DLL install occured. <2013/11/13 18:33:50>INSTALL_MPDRIVER_ACTION <2013/11/13 18:33:58>..MPDRIVER install result is 1/0 <2013/11/13 18:33:58>MPDRIVER is installed successful. <2013/11/13 18:33:58>120 sec 120/120 sec 1 min 1/1 pos <2013/11/13 18:33:58>MYPRINT_LOG_WEBREG_INSTALL <2013/11/13 18:33:58>WEBREG IS NOT NEEDED <2013/11/13 18:33:58>MPDriver <2013/11/13 18:33:58>It is the beginning of INSTALL_DETECTPRINTER_ACTION <2013/11/13 18:33:58>Start to network setup. <2013/11/13 18:33:58>beginSection is INSTALL_LAN_PROC <2013/11/13 18:33:58>START Network Setup <2013/11/13 18:34:29>..Network Setup's result is 1/0 <2013/11/13 18:34:29>Network Setup finished successfully. <2013/11/13 18:34:31>TESTFLG is 0 <2013/11/13 18:34:31>MPDriver <2013/11/13 18:34:31>baseRegPath is SOFTWARE\CANON\MSETUP4\InstalledLog\MSETUP_MX920 series_USCD <2013/11/13 18:34:31>szFileName is MSETUP_MX920 series_USCD1311 <2013/11/13 18:34:31>NSS is @Software\Canon\IJNetworkScannerSelectorEX;AppPath@
01-08-2014 10:24 AM
why so complicated
I have w8.1 x64 + Avast
Right click on Avast icon -->
avast! shields control -->
disable for 10 minutes -->
confirm your choice in dialog windows
and you have 10 minutes to install mast-win-mxXXX-1_1-mcd\win\Driver\LANUTIL\SELECTOR\setup.exe
works for me
05-19-2021 06:22 PM
I had this same issue with Windows 10 Pro and Norton Antivirus, and this solution worked for me as well. I disabled Norton Auto-Protect and Smart Firewall, and all of the software got installed including IJ Network Scanner Selector EX2.
