12-14-2015 10:25 PM
Cannon MG3200 printer -- paper was jammed -- got paper out from back of printer. turned printer back on - off /. reset and back on --- now it prints wavy lines -- not straight . Is there a way to fix this.
12-16-2015 10:36 AM
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
03-16-2022 01:16 PM
This is similar to the link that the selfy jammed but is not jammed where the solotion was to clean the grey rollers with alcohal pads... I got 3 more errors after that after one hour this thing is going in the garbage can... no use contacting cannon the warrantee is way over... first jammed then misaligned cartridge then incartatridge error and the incartridge is stuck in and will not come out... this thing has had its day... it must have got all froozen up and is garbage now... you cant leave a printer sit cause the cartridges wear out... dust is your enemy it messes up the rollers... lcd's screens will fade over time or burn out.... and all I need is one picture from time to time... this does not keep things moving...which is exactly what you should do...print something at least every week on the thing even if you do not need to like a post card and then send it to some one or a birthday post card etc...
