Can't set up pixma MG2500
voyeuse
I'm following on screen set up instructions to the point of aligning print heads, but the A4 sheet I've inserted won't print. The document shows in the print queue but that's it - nothing happens. So I can't complete the set up process. I should say this is my third Canon printer and I've never encountered a set up problem before. Any help gratefully received.
The machine's connected by usb to windows 10 64 bit.
19 REPLIES 19
i did the same but nothing worked for me i tried again and again nothing
nathan_oam
Hi
Anyone get a solution to this ? I recently re-formatted a laptop to Windows 10. Now I get a prompt that "Proccessing the installation" however after about 30 mins the printer is not detected.
I have done everything listed here
Thanks,
Nathan
Hi
If anyone is having this issue, this is how I fixed it.
There was a entry listed in Printers and Scanners for my printer. It was just listing the SCANNER and not Printer. After removing it from DEVMGMT.MSC from "Print Queues" and then Refreshing the Hardware - Windows 10 auto installed.
Issue resolved
Thanks,
Nathan
In the past I had been able to install the drivers for my MG2525 printer/scanner in Windows 7 and XP easily. Not so with my new Windows 10 machine. So following the comments here, I completely uninstalled the incomplete drivers, then installed the recommended one from the website. It worked! thanks!
Thank you!. This fixed my Failed installation problem for my MG2555S on Windows 10 x64
this worked for me thanks
OMG - *Thank you SO much!!* I normally don't have much trouble with technology, but this one was a real head-scratcher! Several attempts ended in the printer not being detected and for a moment, it was really seeming as though I'd have to return my new printer. Now, after following your instructions, my installation is complete! I just printed a test page to verify it and everything went off without a hitch. Smiley Happy
Thank you, Nathan!
I signed up on Canon forums JUST so I could say your solution worked and THANK YOU.
For anyone wondering, the solution to the problem is simply this:
While the Canon installation has "hung up" (it's failing to detect the printer even though it is plugged in), simply go into "Printers and Settings" (in Windows) and DELETE the device that you see for the Canon printer/scanner. Once you delete the device, the installation will immediately detect the printer and the installation will proceed and finish correctly.
Come on, Canon! Fix this silly issue.
> Hi
> Issue resolved
> Thanks,
> Nathan
This is a big thank you to flakkster. I enrolled on this forum especially to thank you as well!
I was at a loss with this problem until I read your post. You saved my day and the weekend! Smiley Happy
In fact going to Settings > Devices > Printers & scanners in Windows 10 and removing the partially installed Canon printer(s) entry(ies) worked when the installation stalled, although I must say that I needed to remove the USB printer cord and put it back into my laptop socket again for the installation process to complete and especially for me to have the Canon IJ Scan Utility scanner software installed which will now enable me to start a new project.
Agreed as above. Please Canon sort out this problem at least with the downloadable software. There is no logic for the average or above average computer user struggling to figure out this problem.
I can't remember this being an issue in an earlier version of Windows 10 I have on another computer where this printer was installed with all the complete Canon software a few years ago and with no problems.
This advice finally provided the information I needed to iron out all the bugs and get my Canon MG2525 running, with scanner capabilities---that was the one thing I couldn't previously get. And the key advice you supplied was to uninstall the software that HAD been installed, then download the driver from this website, and finally, re-download ONLY certain other software from the CD-ROM, in particular, the Quick Menu and the User Manual. Thanks so much for leading me out of the woods and into the light!
Holiday
