06-08-2024 10:16 AM - last edited on 06-08-2024 10:24 AM by Arthur
I am running a Dell Computer with Windows 10. I have tried printing a picture on 8.5 in by 11 inch glossy paper. I keep getting the same error message for the error code 4103. Which prompts me to stop the printing queue, change the printer settings and then start over. I have done this numerous times and yet I still get the same message with error code.
I have figured out how to access the paper settings by unselecting "Borderless Printing", which apparently kept me from accessing the option of using 8.5 glossy paper in the first place. I tried the portrait option and the landscape option, but get the same error code message. Can someone please help me with this? I am getting frustrated and may have to dump this printer if it can't do the job i bought it for.
06-15-2024 07:45 PM
You can research here:
Canon Printers: Inkjet, Laser Printers & More | Canon U.S.A, Inc.
06-09-2024 01:31 AM
It can't do the job you bought it for. This is a real cheap printer that cannot print 8.5x11 photos. Can only print 4x6 borderless.
Look at the specs:https://www.usa.canon.com/shop/p/pixma-ts3722-wireless-home-all-in-one-printer
06-15-2024 01:02 PM
So i should go out and buy a better or at least much more expensive printer that I know can do the job?
06-15-2024 07:39 PM
That's not for me to decide. If you want to print 8.5x11 photos, the answer is YES.
06-15-2024 07:45 PM
12-01-2024 01:27 AM
It is true that you can not print with those dimensions on Canon printers, the one I bought is the pixma ts3722 thinking about being able to print my photos with the dimensions described above and like everyone else, I couldn't, but searching for many solutions to that problem, I found one and I'm going to leave it here in case you need it. You only need a format converter, so you can convert photos in jpg format to pdf, once converted, only the printing settings remain. When you upload the photo to the application, upload it as a pdf document and it will give you the option to print as a letter, then use the photo paper you want, just in the settings put plain paper, then just print and that's it.
