05-15-2020 04:16 PM - edited 05-15-2020 05:03 PM
Every time I am trying to print an A3+ document either through Illustrator or Photoshop the printer spits the paper right back out without printing. The latest driver has been installed mac-ix6800-1_7-mcd. The right document size has been specified in the application, the printer and the correct page setup have been selected. I am at a loss, need help! Thanks.
For your info, I am running macOS Mojave version 10.14.6. Letter size and envelope formats print without a problem. Apart from the adobe applications, I am also printing documents through MS Word, no problem with letter-size files, everything prints just fine.
05-15-2020 04:25 PM - edited 05-15-2020 04:25 PM
Hi, Tom6411076!
So that the Community can help you better, we need to know exactly which version of macOS your computer is running along with whether this problem is occuring with any applications other than the ones you mentioned. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
05-15-2020 06:43 PM
When you added the printer to the computer in System Preferences->Printers & Scanners did you add the AirPrint version or the IJ Series version?
05-15-2020 09:00 PM
Hi John,
thanks for the reply!
I added the Air Print version.
Tom
05-15-2020 09:06 PM
Hi Tom.
I'm almost certain that is your problem.
Go back and select "+" to add and wait for the IJ Series version to appear. It could take several minutes.
05-15-2020 09:44 PM
You are awesome, it works!
Thanks so much!
Best,
Tom
