12-07-2016 09:26 AM - edited 12-15-2016 12:25 PM
I will never use the FAX component in my MX922 printer. Can I get rid of it?
12-15-2016 02:39 PM
Hello.
The fax, scan and printer components come together. The fax component takes little to no space on your hard drive. You can delete the icon from Devices and Printers if you do not wish to see it. However, removing the "MP Driver" from your program listing will remove the printer driver, scanner driver and fax driver.
If you need additional clarification, find more help at Contact Us.
12-09-2016 03:45 PM
Hello.
If you do not plan on using the machine for faxing, make sure that you do not connect any phone cords to jacks on the back of the unit.
If you are referring to the "Fax" version of the printer on your Windows computer, this can be deleted.
12-15-2016 12:48 PM
I want to remove Fax to save space, not just remove icons or shortcuts. And, I am concerned that it might affect other actions of the printer. Will removing it from 'Devices and Printers' only unpair it with the computer, or delete it as a program? There is no listing in Control Panel >programs.
The voluminous manual includes nothing about this. I am sorry I bought this printer with all of the bells and whistles that I don't need (Creative Park, etc). I want simply to print, copy, and scan. That's all. There should be a way to do that.
12-15-2016 02:39 PM
Hello.
12-15-2016 04:22 PM - edited 12-15-2016 04:23 PM
Thanks, Michael. Finally a direct answer.
