01-30-2014 01:13 PM
This is a "call to arms" for all of you Canon customers who have had this problem and have had their printers disabled because of it. Please respond with the model of your printer and if you were able to fix it, what you did to fix it.
We need to put pressure on Canon to respond this product defect. It appears to be bad firmware that does not allow the user to override the problem and to continue to use the printer even in a degraded mode. From my investigations the problem is NOT a printhead issue - no way one can be printing fine and then have this error alert without having changed the printhead or ink cartridges!
Canon, PLEASE take this issue seriously and provide a solution across the affected models. If nothing else there should be a trade-in allowance for those printers that have been affected by this product defect.
I have had many Canon printers because they have superior functional specifications. I want to be able to continue using Canon products but only if I can have confidence that this product defect will not destroy my investment.
If Canon is unresponsive our next step should be to aggressively publisize this product defect on social media and on major product vendor outlet sites as negatives reviews.
Forum Users, please reply with your affected model number(s) and with details of any succdessful fix procedure.
04-19-2014 01:16 AM
I have the CANON MG5320, was working perfectly, then in the middle of a print job I got the dreaded U052 error message. The printer has completely locked me out. I have tried to reinstall the print head, I've tried cleaning the print head, no change.
Piece of junk! I spend 3 week researching printers, and this is the best I got. Purchased in November 2012. I want in on the class action suit, this is fraud. Time to fire the guy that suggested this planned obsolescence. I will be actively encouraging friends and family to avoid all CANON products at all costs.
04-20-2014 03:24 PM
Ok, I've done a bit of unscientific research on Canon printer reliability and have come up with the following: It seems that up to about 2012 Canon printers had a very good reputation for quality and reliability. Since then, reliability has begun to slip for some reason. I'm sure the U052 error is part of this. Has anyone else been able to arrive at the same conclusion? Also, is it just my opinion the error could be fixed by firmware upgrades across the rage of affected devices? Current data indicates that Brother is making the most reliable printers despite print quality not being quite as good as Canon's. I think I may look to them for a replacement for my MP830 brick. Any thoughts?
04-20-2014 03:37 PM
I too am having the error on an MP 610. The Canon suggested steps didn't work for me too.
Any other thoughts, before buying an HP, or something else?
04-21-2014 03:53 AM
04-21-2014 06:52 PM
04-21-2014 08:20 PM
Someone said to try and take the Canon printer off your computer... and then reinstall it without the updates and see if it works. Even though I just bought a new printer.. HP....... I am going to try the uninstall, install just to see if it works.
04-22-2014 07:20 PM - edited 04-22-2014 09:01 PM
Add me to the list of upset users! My MG5320 stopped printing between sheets of paper--no changes in cartridges or anything. After replacing cartridges, gently cleaning the print head contacts, reseating the print head, and turning it off & on, the problem remains. How do I get in line for a fix?
(The worst part is that I stockpiled ink on a sale at Christmas--none of the newer ones use the same ink)
04-22-2014 07:48 PM - edited 04-22-2014 07:54 PM
Same issue with my MP610. Sounds like a new printer from a different company is the only answer. Not about to drop $120 on a printer head that doesn't fix the problem. Already out $56 in ink cartridges. What a complete waste of my time and money. CANON (all CANON products)? Never again! Off to Amazon to rate their products accordingly....junk!
04-23-2014 01:58 AM
I found this link after my MP610 failed with the U052 message. I have used it for 2 years now, and was only doing a standard print job when it failed. I have tried resetting the print head, cleaning it, resetting the printer, and leaving it to rest for a few days. Occassionally the printer will show error message 5200 after powering up again, only to go back to U052 after a while. I live in the Netherlands, so does anyone have experience getting a replacement printer in Europe? I will contact Canon later today, and see what the possibilities are. Thanks for all your postings! My next plan was to try to buy a replacement printer head, but I can see that it's been tried and doesn't work.
04-23-2014 03:09 AM
