01-30-2014 01:13 PM
This is a "call to arms" for all of you Canon customers who have had this problem and have had their printers disabled because of it. Please respond with the model of your printer and if you were able to fix it, what you did to fix it.
We need to put pressure on Canon to respond this product defect. It appears to be bad firmware that does not allow the user to override the problem and to continue to use the printer even in a degraded mode. From my investigations the problem is NOT a printhead issue - no way one can be printing fine and then have this error alert without having changed the printhead or ink cartridges!
Canon, PLEASE take this issue seriously and provide a solution across the affected models. If nothing else there should be a trade-in allowance for those printers that have been affected by this product defect.
I have had many Canon printers because they have superior functional specifications. I want to be able to continue using Canon products but only if I can have confidence that this product defect will not destroy my investment.
If Canon is unresponsive our next step should be to aggressively publisize this product defect on social media and on major product vendor outlet sites as negatives reviews.
Forum Users, please reply with your affected model number(s) and with details of any succdessful fix procedure.
10-19-2015 02:15 PM
Did you get anywhere on this?
10-20-2015 04:34 AM
I suggest you read the thread!
09-29-2017 07:54 PM - edited 09-29-2017 08:03 PM
Do you have any update? I have the MP 960 as well..
Interestingly, I had a small Canon camera - top notch - right after the waranty ran out, it got an error that when I googled it, was the same type of thing. No fixes. Not addressed by Canon. Nothing. Bummed because I've had like 4 Canon printers over the years and they've all been great. Only got new cause I'm a junkie 🙂 I've had this one for probably 10 years and just now getting this error.
05-02-2014 11:34 AM - last edited on 05-02-2014 12:27 PM by Stephen
I had this error with my canon printer that showed up one day with no warning.
Using my powers of deduction and understanding how power supplies work I found an easy solution to fix that that anyone can do in about 1 minute.
If you would like to know how to do it email me.
Removed email address per FORUM GUIDELINES
05-02-2014 11:51 AM
05-02-2014 11:53 AM
05-02-2014 11:56 AM
05-02-2014 12:08 PM
Ok understood. I worked on mine but I dont know if it will work on all of yours but I sure hope so.
Didnt want to post it until I tried with a few people first to see if it worked on all.
Think I will buy some on ebay to see if it works.. so hold off on the resolved status to see if It works on others first.
Mabye I just got lucky
05-02-2014 12:25 PM
05-02-2014 12:16 PM
