08-18-2015 01:41 PM
08-21-2015 02:38 AM
Hi JCeithaml,
Cleaning both areas of the printer glass may resolve the issue you are experiencing with the printer. To do this, please open the printer cover to get to the platen glass. With a moistened swab (you can moisten the swab with water or glass cleaner), please clean the small strip of the glass that is off to the left hand side, separated from the main scan area of the glass. Once the small strip of glass has been cleaned, please also clean the main platen glass area of the printer with a moistened, lint free cloth.
Once the glass is dry, please attempt to make a copy again. If you still experience the same issue, please call or email us using one of the methods on the Contact Us page for further assistance.
08-26-2015 05:11 PM
All glass is clean, did nothing to resolve my issue. It is a perfectly printed 1/2 wide black strip down the right side of the page
10-24-2015 12:26 PM
Did you ever get your issue resolved? I'm having the exact same problem and not sure what to do!
Thanks!!!
10-26-2015 09:19 AM
Hi tfeichtel,
It is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
10-28-2015 01:38 PM
The only way I was able to resolve the issue was by purchasing a new printer. Canon was no help unfortunately. If you will notice the 1/2 inch dark ine is actually an extremely dark reprint of the middle of the page you are trying to copy.
Good luck in your endeavours
10-28-2015 05:35 PM
