Will the PIXMA MG2922 scan a document into a PDF?
victortalha
@GoldCoastPub @VictorTalha @Real_Leads on Twitter -
3 REPLIES 3
Ramona
Hi victortalha,
The printer comes with a program called the IJ Scan Utility that can assist you with scanning in documents into a PDF format.  To scan a document in as a PDF, please follow these steps:
1. Place the first page of the document you would like to scan on the platen glass of the printer.
2. Start IJ Scan Utility.
3. In the Canon IJ Scan Utility window that opens, click SETTINGS.... in the bottom right of the window. The Settings dialog box appears.
4. Click the DOCUMENT SCAN option on the left pane of the window, then set the item size, resolution, etc. as required.
5. In the SAVE SETTINGS section of the window, you will select the save format and location of the document you are about to scan.
a.) In the FILE NAME field, specify the name you would like to give the file. By default the filename will begin with IMG; you can remove IMG and change it to whatever you would like to name the file.
b.) In the DATA FORMAT field, use the drop-down arrow to select the desired option. If you are scanning a multipage document, select the PDF (Multiple Pages) option.
c.) In the SAVE IN field, please navigate to the area where you would like the file to be saved once it is scanned in. By default, the file will be saved in the MY DOCUMENTS folder.
6. Once all settings have been selected, click the OK button at the bottom of the SETTINGS (DOCUMENT SCAN) window. The IJ Scan Utility main screen appears.
7. Click the DOCUMENT button. Scanning starts. Click the CANCEL button to cancel scanning if needed. Scanned images are saved in previously selected folder location specified in the SETTINGS... window.
Hope this helps!
If I threw away the CD with the IJ Scan Utility on it, is there nowhere to download that utility online? Have I lost the ability to scan/copy with this printer now?
Since it appears I have lost the CD that came with the printer, is there no other way to get the scan function to work? Can I not download the utility somewhere?
