03-17-2021 03:57 PM
I have the TS9521C printer. When I use the softward and choose "photo layouts" it will not print and I receive the "an error occured while printing". The only solution I see on the community board is the person had a laptop which was "wiped clean" and they re-installed Windows 10. That solution doesn't work for me. Has anyone else had this issue and have a solution. It does print using other print software on my computer and I have been able to print 4x6 prints using the Easy PhotPrint Editor.
Thanks in advance for any help.
03-18-2021 10:36 PM
the same happens to me, I can print with other apps and with the canon android app but not with the windows 10 Easy PhotoPrint Editor
03-20-2021 11:18 AM
In order to solve this issue you must go to this link:
https://www.catalog.update.microsoft.com/Search.aspx?q=KB5001649.
Download the files who is right for your operating system (x64 or x86)
For me it worked perfect for two of my laptops.
Good luck
03-21-2021 02:55 PM
I updated from Windows Update, it did not work. Then I went to the link you provided. It is working fine now, Thanks
03-21-2021 03:04 PM
I am happy to hear that.
Good luck.
