05-01-2017 03:20 PM
Why can I NOT print 8 x 10 photos on 8 1/2 x 11 photo paper on my Canon MG 2400?
I get error message about media and paper size not matching. Manual indicates that with photo paper i can only use and print 4 x 6 or 5 x 7 prints.
Help please
05-02-2017 02:21 AM - edited 05-02-2017 02:21 AM
Hi rh2ohouse,
Printing on photo paper sizes other than 4x6 or 5x7 is not supported by the PIXMA MG2400; to print on other paper sizes, you can select the PLAIN PAPER option in the printer driver instead of a photo paper.
Hi rh2ohouse,
05-02-2017 08:47 AM
Yes I saw that was possible but I then used phot instead of the selection the selected plain paper to be able to print a larger picture. The resulting photo was not very good. It actually came on better on the plain paper. Guess I do not understand why the printer is set up this way - not being able to use larger photo paper.
Thank you for your help.
12-27-2017 11:43 PM
Yeah this is bizzare I'm looking all over the web for a solution but it seems I'm just going to have to return my Canon printer and grab an HP or something. The plain paper setting does not produce a good photo no matter how high you set the quality it is very blurry and awful.
05-04-2022 01:08 PM
I found the "Plain" paper and "High Quality" settings made very acceptable photos on glossy 8x10 paper on my Canon MG-2922. Just Sayin...
08-05-2022 02:54 AM
This is crazy!! Here it is 2022, 5+ years after this thread started and there is no solution. I just bought a TS207 printer, that was promoted as a photo printer, because I have to print a lot of A4 sized photos in high quality, and discovered I have the same problem that started this thread. Why doesn't Canon tell us about this limitation? Why doesn't Canon respond to this thread?
08-05-2022 08:11 AM
It’s pretty clear from the product description that only 4x6 photo paper is accommodated.
08-06-2022 09:15 AM
If you are trying to imply that we are all idiots, you failed . There's nothing in your screenshot that says it's clear that 4x6 is the maximum size allowed for photo printing. Somewhere else in the documentation it says that 4 by 6 is the maximum size for borderless printing, but nothing that says for y6 is the maximum for plain photo printing on glossy paper.
