01-23-2017 08:04 AM
New to canon product, I have a problem with DPP4 :
after install it, all is working well, exept when i want to convert for raw ton JPG or TIFF.
The first time i convert a picture juste after the install, it works, i have the window with the progress bar, and the jpg is created.
then if a want to create a second jpg, the window with the progess bar never show, and i have in my task manager a process "Digital Photo Professional 4 Batch-> DPPBatchSaveMainForm" that never finish...
if i close and restart the DPP4 app, or restart computer, it does not change anything, i cant convert more raw to JPG...
i uninstall all canon software, clear all preference file, and all folder, restart computer, install all software again, the same thing happen, it work onces and never again.
computer : window 10 pro , I7 16G of ram, nvidia 970
does anybody have a idea ?
hope that this message is clear to understant, i'm french and not good english writer.
thank you for any help !
Frédéric
ps: i have also try this solution from the forum:
Try downloading and running this Microsoft uninstall fixit tool. It's worked for me when I have programs acting strangely.
https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed...
nothing change
08-10-2017 06:39 PM
@Lilreeces10 wrote:Mine is doing the same freaking thing SMH...I usually don't have issues with it, but all of a sudden it just stopped converting my pics about a week and a half ago. I hate LR. Anybody figured out the solution? I hit convert and save like usual but then the progression box just stays blank like below and nothing is processed:
for the problem?
Did you select any files prior to invoking the command?
08-10-2017 06:46 PM
Nope...I do prefer the updated version and I might try and install it later but I went ahead and just downloaded the old version from the CD that I kept in my T2i box.
09-02-2017 01:40 PM
Absolutely the same problem with DPP for Windows 10 (64 bit) and I have no ideas how to solve it. I've just installed ver. 4.7.1, but it didn't help.
09-02-2017 03:40 PM
@rockyraccoon wrote:Absolutely the same problem with DPP for Windows 10 (64 bit) and I have no ideas how to solve it. I've just installed ver. 4.7.1, but it didn't help.
You really should start a new thread for your issue, instead of piggy-backing onto someone else's thread. Someone else is probably now receiving alerts about your issue. Not good manners.
You should start your own thread. Describe your hardware, version of your operating system, version of DPP, and what steps you take to reproduce the problem. If you call Canon Support, they will ask you the same questions.
09-05-2017 12:15 PM
_Mac_, thank you. Your proposal to run DPP in admin mode worked in my case.
Waddizzle, thank you for your advice. Though your advices didn't help anybody in this thread.
12-24-2017 03:53 PM - edited 12-24-2017 03:55 PM
I just resolved the same issue on my Windows 8.1. The problem was all about user permission. The running DPPBatchSaveMainForm process was trying to get something done which I was not allowed to get like "write" or "modify".
You can either give more permissions if Windows system lets you do it or just move the Digital Photo Professional 4 folder to the place on your PC with full permissions. In my case it was local disk D. Even moving the folder with DPP4 one step up outside Canon folder helped me. And here we go.
04-12-2019 05:05 AM
Hi all,
i had the same issue when converting RAW to JPEG with DDP 4 - progress bar starts but stops 1 mm befor the end end generates error.
Just loaded and installed DPP 4.10.0 that is the lates now, and all works. Can't tell you why but I'm just sharing experience.
good luck,
frankk1
04-12-2019 03:41 AM
I have the same issue_
I'm using DPP4 and Canon 5DM4 raw files
progression goes to the end minus 1 mm and never ends really but RAW is converted to JPG and it works
all following attempts look working, so the bar progesses until the end, but it says "error" and no one jpeg is produced
hop it's clearly explained...
any solution for this ?
thanks
