10-26-2016 11:21 PM - edited 10-26-2016 11:26 PM
Can someone let me know if you can disable this from auto launching. I would like to use capture one and have the eos utliity on my computer as a backup plan. With the eos utility auto launching it will not allow capture to mount the camera. I tested it on my tower where I don't have the utility and capture works perfectly. So I am thinking it's the auto launch feature or it could just be that eos is installed and that takes priority.
I'm using eos utility 2 - 2.14.20.2 with a mark II
my os is Yosemite 10.10.5
Thanks in advance for any help
Cheers,
Brad
11-03-2016 01:56 PM
In the Canon Utilities folder in Applications there would be an EOS Utility folder. In that folder would be an app EOS Utility and a folder EOS Utility 3. If you run the app it gives you the icon on the top menu bar.
10-27-2016 07:02 AM
If you right click on the EOS Utility icon in the top border of the screen you should be able to select don't start EOS Utility when camera is detected.
10-27-2016 09:34 AM
I've tried that and I get no pop up or dilioag box for that option. I am 99% sure I truned this feature on a long time ago too. It's crazy I've searched everywhere. prefs, system prefs, image capture, os backend. Thanks for you help! I got capture one to work with it now but it's anoying to have to quit it and reconect to capture everytime. I'll keep on looking for it today.
Cheers
10-27-2016 09:48 AM
If you are in Image Capture I believe you need to have your device connected. Then at very bottom of left hand side there will be a triangle. Click that and you should be able to select software to be used when IC detects that device.
11-03-2016 07:34 AM
I did look at image capture and that was set to none. Strange there has got to be a fix
10-27-2016 09:18 AM
Go into Image Capture and change the preference to whatever software you want to auto-start.
11-03-2016 07:39 AM
11-03-2016 12:41 PM
can you send me a screen shot of this disable button? I don't see it anywhere. I've clicked on every inch of the start screen. I'm getting a mark III today. so I'll be using the utility 3 now. but I still don't see the icon your speaking about.
thanks for all your help BTW. This is driving me crazy.
11-03-2016 01:10 PM - edited 11-03-2016 01:12 PM
@bradcarr wrote:can you send me a screen shot of this disable button? I don't see it anywhere. I've clicked on every inch of the start screen. I'm getting a mark III today. so I'll be using the utility 3 now. but I still don't see the icon your speaking about.
Start up EOS Utility. In the little square window in (usually) the lower right corner of the screen, right-click the EOS Utility icon. Click "Do not launch ...".
11-03-2016 01:56 PM
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
