02-07-2023 12:50 PM
I am trying to download the EOS 2 Utility for my Canon NON WIRELESS 60D so I can get the photos off the memory card. The computer I use already has EOS 3 Utility downloaded for my Canon mirrorless M50 Mark II. Is there any way to have both utilities on the same computer?
07-05-2023 11:17 AM - edited 07-05-2023 11:20 AM
Go to the 1D X Mark III support site. I know it’s there.
I just checked. Also on 1D X site. Need to select W10.
07-05-2023 11:44 AM
Uninstall EOS Utility entirely. You don't need it and it is confusing the issue.
10-19-2024 10:13 PM
Respectfully Disagree.
I have 12 years of 60D photos automatically saved in directories named with date/time by UTIL2.
Sure, I COULD replicate that feature manually after the drag&drop.
10-19-2024 10:35 PM
Have you considered simply removing the card from the computer and using a USB drive on your computer to upload the images? It will be faster than the USB connector on the 60D and likely the 5DII, and just as simple to do. Then you don't have to worry about software at all.
10-19-2024 11:53 PM
I'm sorry I didn't thoroughly explain myself.
There is a feature of UTIL2 image transfer that I require: Destination Folder and subfolder creation, as described within the "Preferences Tab". This is far beyond the simple drag-and-drop workaround as suggested.
UTIL2 interrogates the actual EXIF data and creates multiple subdirectories inside my CANON directory. I request shooting year\month\date and the format YYYY-MM-DD the configuration settings tabs, then UTIL2 reads and writes, neatly organizing my archive.
I could create these multiple directories manually, but that negates any speed advantage over USB manual transfer. Obviously, the issue isn't the transfer itself, it's the benefits of using an official CANON utility, built for the purpose. I also use the camera control feature.
Perhaps you can suggest a more appropriate thread in which this dialoge belongs. I will be embarrased if there is one already. Better yet, a suitable download utility that will replace UTIL2.
Thank you for your expertise
10-20-2024 01:14 AM - edited 10-20-2024 01:20 AM
The most appropriate action is actually to start your own thread, please. It confuses everyone when we get different people creating their own posts and looking for solutions - we get crossed interchanges, as in this case where I was addressing the OP. Each needs to be dealt with separately even if they seem the same. At this stage 2 people including yourself have engaged in the thread started by svjphotog.
