does canon camera connect work with samsung z flip 5?
JMcKinnon1966
Cant get my t6 and my z flip 5 to synch up
5 REPLIES 5
John_Q
Hello JMcKinnon1966,
The system requirements on an Android device are Android versions 11/12/13/14/15. As long as your phone is running one of these versions of the Android operating system, then you should be able to connect your EOS Rebel T6.
Let's try a fresh start. Let's start by resetting the camera wireless to default settings and going from the top through the process.
  1. Turn the camera on and press the “Menu” button. Navigate to the first tools tab which is labeled in yellow and has a symbol of a wrench.
    2. Highlight and select “Wi-Fi function” on this menu screen by pressing SET on the camera.
    3. Press the “DISP” button on the camera.
    4. Select “Clear Wi-Fi settings” and then select “OK” when it’s displayed on the camera’s screen.
    5. If the Wi-Fi/NFC option shows “Disable”, then select “Enable” to enable the wireless feature on the camera. You may need to provide a new nickname for the camera.
    6. Then highlight and select “Wi-Fi function” on the menu screen by pressing SET on the camera.
    7. Select the icon for connecting to the smartphone.
    8. Select “Easy Connection” and highlight “OK” on the bottom right of the screen. Press SET.
    10. The camera LCD screen will display the SSID name and new password which is labeled “Encryption key”.
    11. Go to the Wi-Fi network screen on your phone, select the camera to connect to and then enter in the new password when prompted.
    12. After connecting to the camera's Wi-Fi on the phone please navigate and open the Canon Camera Connect app. Please wait up to 30 seconds until you see a window pop up which will state “New camera found”. It will display the camera within this window. Tap on your camera model to connect to it.
    13. On the back of your camera you will see your phone appear on the LCD screen. Press “OK” on the bottom right. This will finalize the handshake between the two devices.
JMcKinnon1966
I'm running android 15 but it still won't work on my z flip 5
Duplicate post.
https://community.usa.canon.com/t5/EOS-DSLR-Mirrorless-Cameras/EOS-Rebel-T6-won-t-connect-to-Samsung...
I saw this and I decided to keep it as two separate threads as one deals with the Canon Camera Connect app and the other deals with the camera.  I decided they were sufficiently distinct to warrant individual threads.  Thanks for looking out!
"What's won't work"?  We need more information.
Do you see the cameras wireless broadcast (SSID Name) on your mobile device.  Does it prompt for the password when you attempt to connect to it?
Do you receive an error message.  If so what is it.
