07-22-2024 08:25 AM - last edited on 07-22-2024 08:49 AM by James_C
Hello team,
I have camera R6 mark ii and while I using it to capture photos shows error code 80 , (87 around humid temperature).
Solving this error temporary by re insert battery again and again after capturing moments.
Is there any permanent solution for this.
Regards
Samir Barot
Samir Barot
07-24-2024 06:46 PM
Hi Samir2199,
I'm sorry to hear you are seeing Err80 on your camera. That is shown when the camera either detects an electrical malfunction in the camera, or an issue with writing or reading files from the memory card. There are somethings to check with that error.
The first thing is to try loading a different battery in the camera. Sometimes if a battery is malfunctioning and over or under powering the camera it can cause that error. If the issue continues the next step would be to load a different memory card in the camera. Sometimes if a memory card is malfunctioning it can cause that error. If you still see the error at that point the last thing would be to attach a different lens. Sometimes if a lens has a short in it that error can be shown. Swapping out each piece one at a time would help narrow down what piece may be the cause.
If the error continues showing after swapping out all of those pieces at that point we would recommend sending the camera in for repair.
The Canon U.S.A., Inc. online repair portal allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
