Problems with the canon xf plugin for fcp 7 Can't log and transfer mxf files.
jameskendi
Hi
I can't log & transfer mxf files from a c300 camera in FCP 7 even though I installed the xf plugin.
When I looked at canon's website this link comes up but it doesn't work.
http://usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200206002EN.htm
Any suggestions?
Or other plugins that might work?
Thanks,
James
1 REPLY 1
Tim
Hello jameskendi,
The most obvious reason we can tell as to why this may not work properly is the version of FCP you are using.  You mention using FCP 7, although the plugin is specifically for FCP X.  This is why you're having such difficulty.  If possible, we'd recommend using an updated computer and or software to process these files.
