10-28-2023
09:30 AM
09:31 AM
I am not able to open .CR3 with Digital Photo Professional 4 in macOS Ventura 13.5.1
I don't know what. is wrong with application I downloaded it form Canon.
Anyone have idea how to fix it.
Thank you!
10-28-2023 10:02 AM
If the file name appears with a question mark "?", it means the OS cannot read the file type. It may mean the file is corrupt or is being read incorrectly. Are you naming the files differently?
Can you view the image file(s) on the camera. How are you transferring them to the MAC?
10-28-2023 10:46 AM
Thank you for the reply.
File name is correct "Filename.CR3" and I am able to open it with Adobe tools.
Yes I am able to view images on camera. I connect my M50 Mark2 with mac through EOS utility and transfer them into my laptop.
10-28-2023 12:12 PM - edited 10-28-2023 12:14 PM
Greetings ,
I need to do some research but I thought I remember reading or seeing a post from somebody previously where Adobe was doing something to the files after import. Somebody else may remember before I reply back.
Also, when you say Adobe tools does this mean Adobe camera raw? And if so what version are you running?
10-28-2023 12:19 PM
Adobe Photoshop and Light Room.
10-28-2023 12:44 PM - edited 10-28-2023 12:46 PM
Which versions do you have though?
I personally have the following:
Assuming you have Creative Cloud, launch that on your Mac and visit the Updates panel. I will show the specific versions of what you have.
10-29-2023 02:49 AM
I don't have. problem with Adobe tools I am facing issue with Digital Photo Professional 4.
DPP4 is not able to read .CR3 files. Its shows "?" in box. I added a attachment please have a look.
Thank you.
10-29-2023 06:26 AM
Can you post a sample file to One Drive or Dropbox so we can evaluate issue?
10-29-2023 12:29 PM
Is your version of DPP 4 the most recent? If not it might be good to check for updates.
If you have a card reader slot on your Mac, I suggest removing the memory card from your camera and write protecting it by moving the switch on the card and inserting it into the card reader on the Mac.
Then in DPP navigate to /Volumes/EOS_DIGITAL/DCIM/100CANON/ (might be some number other than 100) and try opening a CR3 file. If that works, save from DPP to a folder on the Mac hard drive. Adobe tools might have modified the files so that DPP can no longer read them but only Adobe software. I do not use any Adobe software, so I do not know if this is what happened. If the memory card is write protected, then the files cannot be modified.
Apple Photos.app may also be able to process these files, but I prefer DPP.
In finder, one may go to /Volumes/EOS_DIGITAL/DCIM/100CANON/ and preview the CR3 files that are on the memory card. Finder can also copy from the memory card to the hard drive. If the memory card is not write protected, then finder will write hidden files to the memory card that might confuse the camera.
01-27-2025 07:53 PM
I have the same problem lately.
Did you ever find a solution to this problem?
