Image stabilization EOS VR Utility
No1umfan
Does anybody know if the image stabilization in VR utility is supposed to use GPU because it doesn’t look like it’s using it even though I have GPU checked in the tools menu. It’s all 100% CPU.
Using R5 with canon dual fisheye lens. 13 th gen intel I7-13700K, Nvidia 4070
Greetings No1umfan,
The image stabilization function within the EOS VR Utility is a function that uses the CPU for processing rather than the GPU.
5 REPLIES 5
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, we will need to know what Canon camera gear you're using.  Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you
No1umfan
Greetings No1umfan,
This was the only documentation I could find, so thanks to NatalyaP for clarifying.
https://sas.image.canon/st/en/vru.html
I am curious and wondering why there is even an option to use a GPU if the CPU is all that's going to be used anyway?
To further my confusion, the link that Rick (shadowsports) posted states that "The processing performance should be lower on a computer that has no supporting GPU."  I also found this video that, starting at 5:30 in the timeline, suggests that you should select the GPU for processing, at least on the Mac he is using. I don't have this software, so I have no first hand experience but I do have DPP 4, which also has an option to use the GPU, and it doesn't seem to be that effective in my testing. So maybe the same applies to the latest VR app?
Newton
Holiday
