06-08-2023 01:58 PM
I recently started seeing this message in Windows 11 Photos, which I have seen before, but now I can't move past it. I am trying to transfer photos from my SanDisk to the laptop. I think it may have something to do with Canon software, which I recently downloaded. I can transfer to my just fine using bluetooth/WiFi. Anybody have a suggestion?
06-13-2023 08:30 PM
Problem solved. Somehow I had begun recording all photos to card#2. As long as I have owned this camera, I had never used card #2 and I do not recall making this change. But, my normal card 1 was indeed empty, but when I connected via bluetooth, everything showed just fine. I ordered a new card reader, but my existing card reader works fine, so I'll probably be returning it. Simple solution, just took me about 2 weeks to figure it out. Thanks to those who tried to help me figure this out.
06-08-2023 02:12 PM
Tell us what you’re doing. What camera? Are you using a card reader?
Are you trying to connect to the camera with a USB cable? And, then move the files?
06-08-2023 05:12 PM
I’m attempting to download photos to my laptop using a USB card reader - I have an R7.
06-08-2023 06:27 PM
Why not just copy the files to a folder on your computer using File Explorer before opening in Windows Photos?
06-08-2023 10:48 PM
Actually, I would question whether it is the camera. How good are you at updating the Windows software? There have been a slew of updates over the last wee while, some of which are to do with connectivity security.
06-10-2023 01:11 PM
I tried this - the two folders DCIM and MISC, and the subfolders under DCIM (100EOSR7 and CANONMSC) show empty, when I know I have photos on the card.
06-10-2023 01:15 PM
My windows software is up to date. And the Windows help that seems to be the closest to my situation is designed for phones and indicates it has to do with USB settings. I don't find any similar choices on the R7:
Note: If you're using an Android phone and Import isn't working, you might need to change your phone's USB setting to allow it to transfer photos.
06-10-2023 05:33 PM
If you can see those folders in File Explorer, then you should be able to see the picture files in them. What type of picture files are on the card? JPEG or RAW?
06-11-2023 05:08 PM
.JPG files - and yes, I ought to be able to see the files in explorer, but I don't - I am starting to think I have a bad card reader ...
06-11-2023 05:36 PM
Sounds like you may be right about the card reader (or cable).
