12-16-2018 03:27 AM - edited 12-16-2018 03:33 AM
Hi folks,
Our firm has just upgraded our AV machine to an AMD Threadripper 2 2950X/Gigabyte X399 from an older Intel 5960X/Asus x99. Huge (and greatly appreciated) speed boost in everything we do, but can no longer connect a 5D Mk IV via USB connection. Software environment is a fresh install of Win10 Pro x64, v1809.
Attempted troubleshooting steps:
This problem appears localised to the new Ryzen-based production environment, as the EOS3 utility and camera are able to sucessfully connect via USB on the older Haswell-E Intel machine and, as a test, on a new-out-of-box Surface Pro 4.
Any further suggestions or troubleshooting steps to attempt would be greatly appreciated, as we shoot purely in large-format RAW and so the file transfer times via wifi are cripplingly slow and seriously frustrating.
08-27-2021 09:20 AM
Firmware update 1.3.3 solved the USB 3 problem with AMD Ryzen processor. Today I upgraded my camera and connecting to USB 3 works flawless
08-27-2021 11:09 AM
08-27-2021 11:44 AM
Glad Canon finally fixed it after a year + of pure silence. Very poor communication by Canon; they never even acknowledged the defective firmware with regard to AMD chipsets.
09-10-2021 03:00 AM
Thanks all for your contributions - confirming 1.3.3 has also solved this problem for us.
Extremely annoying that it's taken the best part of three years for this to be resolved, with still no actual communication from Canon, but glad we're at the end of the road.
01-08-2022 10:42 PM
Firmware 1.3.3 does not solve this issue. I have an ASUS Zenith Extreme Alpha X399 board with a Threadripper 2950x and my 5D Mark IV is running firmware 1.3.3 and I am still unable to use EOS Utility 3 when connected to a USB 3.1 port (the application just hangs on the splash screen, just like it's always done). Connecting to a USB 2.0 port works fine. This still needs to be resolved.
07-21-2022 02:09 PM
I agree. The new firmware fixed it on my Ryzen Lenovo laptop, but on my desktop PC (despite all the latest drivers and mobo firmware) I have the same USB3 issues connecting the Canon MKIV to any USB3 or 3.1 ports. Frustrating that the Canon 5d mkIV works perfectly on USB3 with my 10 yearold intel-powered desktop. While there is a fix that has helped many, there appears to be gaps in the solution.
07-21-2022 02:42 PM
The off the shelf AMD machines seem to work with the firmware update. It seems like the issue seems to occur most often with home brewed AMD platforms.
07-21-2022 03:44 PM
Mine is a NZXT pre-built.
