06-13-2021 07:23 PM
I'm trying to get Remote Shooting working with my laptop, but have spent a few hours without success. I'm using a Rebel XS connected to a MacBook Pro running macOS 10.15.7. I've tried EOS Utility 1, 2, and 3 to no avail. Has anyone had success getting this configuration to work? (If it makes a difference, I'm using a mini USB to USB 3 cable - i.e. one that connects the camera to the laptop with no adapters.)
06-16-2021 02:35 PM
Since Image Capture sees the camera the connection is good.
Check the Security tab in System Prefernces and see if you need to authorize EOSU to access files and folders.
06-13-2021 08:14 PM
The PIN out on the cable you are using might be the issue. Does the MAC recognize the camera at all?
06-16-2021 12:03 PM
06-16-2021 12:04 PM
06-16-2021 01:10 PM
What version of EOSU 2 do you have?
06-16-2021 01:53 PM
06-16-2021 02:35 PM
06-16-2021 04:22 PM
You might try switching modes of the camera between PTP and PC communication.
06-16-2021 04:36 PM
