EOS Utility downloading duplicate photos from dual cards in EOS 5D Mark IV
rvd1000
Hi there,
I just updated the 5d mar IV with an extra card, so that it now has 2 cards installed.
I set up the cards so they work as backup (the 5d saves the same image to both cards).
My issue is when plugging the 5d into the usb and eos utility opens and I import new images: it imports each image twice (once from each card, and with unique file-names, as if it was 2 different images).
Is there some way I can change this behavior, such that eos utility will import only from one card automatically and skip the duplicates on the other card?
Basically I would like the import to behave similar to how it did when using one card only. I only use the second card as a safety backup, so I am not sure why it saves the same image to both cards as if they were 2 different images (I expected it to save the snapped image to both cards using the same file-name on both cards, and then only import the image once.)
I have looked for settings in eos utility to set this behavior but can't find any.
On the 5d I set it to record to multiple and playback from slot 1.
Any tips on how to avoid importing the duplicates from the second card when using auto-import in eos utility?
I can't be the only one having this issue, one would think....
Thanks!
23 REPLIES 23
Thanks Rodger, will test that!
What is your workflow, with 2 cards in a backup configuration?
I have just been popping one out before transferring when I set them both to record (for non-critical stuff I just use a single card); I am glad you brought up the question which caused me to research the issue.  Hopefully a revised version of EOS utility will provide an option under preferences to choose either card instead of both.
Hopefully the suggestion works because I haven't tried it yet and after shooting a high school football game in 33 degree wind/rain/drizzle/snow Friday night I am not anxious to go out and shoot anything  to try it right now.  One of the players told me after the game they had an informal betting pool as to which quarter I would fall in the mud because all of the officials and two of the coaches ended up falling before the game was over.  I should have worn cleats because the sidelines were horrible and unlike soccer, American rules football plays don't stop cleanly at the sidelines so I did several fast backwards runs with 1DX M2 300mm F2.8 and 1DX 70-200 F2.8 camera/lens setups.  The cameras and I survived without falling 🙂
My wish for EOS utility is to allow automatic selection of download folder by camera.  Right now the 1DX 2 and 1DX dump their files into the same directory by date but it is pretty easy to move the different camera files because of the different naming convention.
Rodger
It's the end of 2022 and still no option to select automatically download only from the 1 card. Shame.
Not sure what the problem is. Just select the card you want to download from:
It's a matter of automation. With the one card only you can select to start EOS Utility and automatically start downloading as soon as the camera connects to the PC. With the two cards, you need to do this manually or deal with double space and time needed for download. Additionally if you keep RAW on one card and JPG on second, the tool will rename the file to Photo.raw and Photo_1.jpg what result in no raw+jpg grouping in the DDP or LR. Original files on the cards are Photo.raw (card 1) and Photo.jpg (card 2) so obviously the EOS U tool renames the files from the second card.
This sounds way over complicated.  Multiple solutions have been offered.
Waddizzle - Downloads primary and back up correctly (As designed)
John - Select the card you want to D/L from
Me - Remove a card before connecting the camera (Takes an extra 6 sec), or use a card reader) what I do anyway
The utility doesn't know what your shooting configuration is.  Nor should it need to.  Duplicate, Start card A, go to card B when full, Copy RAW to card A and .jpg to card B, etc.  This behavior is as designed and perfectly normal.  The duplication thing is 100% avoidable by taking the card you don't want copied out before connection.  You'd have to select the behavior somewhere, either in the program or by removing the card.
If its that important to you, and you want it considered in a future release of the EOS Utility, please make a feature request.  Support portal > [+]Feedback > Product.
The most obvious solution is to SELECT the files you want downloaded, instead of using the “automatic” download feature and complaining about the results.
rvd1000
The point you are missing is that no one wants to have these kind of duplicates created on their PC...
Thank you.
No one is missing that point. Whenever one selects a simplified “Automatic” approach there will be compromises. Auto ISO won’t let you select the ISO you want. Auto Exposure won’t let you select the Tv/Av combination you want.
As Rick pointed out there are many possible recording combinations, including various modes on the same two cards. Today I want RAW+JPEG. Tomorrow a critical shout where I want RAW+RAW etc.
Friends and Family
