EOS Utility 3.18.5.13 installer Crashes After Launch
Mostly_Birds
Even a freshly downloaded copy of the latest EOS Utility (EU-Installset-M3.18.5.13.dmg)  crashes shortly after launch. The install fails. The summary crash report generated by Mac OS 14.6 follows. My comments and questions are after the end of the summary.
Translated Report (Full Report Below)
Process:               UniversalInstaller [62617]
Path:                  /var/folders/*/UniversalInstaller.app/Contents/MacOS/UniversalInstaller
Identifier:            UniversalInstaller
Version:               ???
Code Type:             ARM-64 (Native)
Parent Process:        Exited process [62616]
Responsible:           OFICore [62612]
User ID:               501
Date/Time:             2024-08-06 08:55:46.9124 -0600
OS Version:            macOS 14.6 (23G80)
Report Version:        12
Anonymous UUID:        9E77241D-C92D-EAEA-FD94-8261AFE3C161
Time Awake Since Boot: 430000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes:       0x0000000000000001, 0x0000000000000000
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [62617]
VM Region Info: 0 is not in any region.  Bytes before following region: 4331274240
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      1022a0000-10230c000    [  432K] r-x/r-x SM=COW  /private/var/folders/*/UniversalInstaller.app/Contents/MacOS/UniversalInstaller
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   libsystem_platform.dylib             0x195b0f904 _platform_strlen + 4
1   UniversalInstaller                   0x1022d0cdc std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>::basic_string<std::__1::nullptr_t>(char const*) + 36
2   UniversalInstaller                   0x1022c00f0 canonsoft_uix::CServiceLogUtil::WriteSystemInformation() + 628
3   UniversalInstaller                   0x1022a6374 canonsoft_uix::CUIXApplication::ApplicationWillFinishLaunching() + 188
4   UniversalInstaller                   0x1022a4320 -[UIxApplicationDelegator applicationWillFinishLaunching:] + 64
5   CoreFoundation                       0x195bb6144 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 148
6   CoreFoundation                       0x195c4a3d8 ___CFXRegistrationPost_block_invoke + 88
7   CoreFoundation                       0x195c4a320 _CFXRegistrationPost + 440
8   CoreFoundation                       0x195b84678 _CFXNotificationPost + 768
9   Foundation                           0x196ca12c4 -[NSNotificationCenter postNotificationName:object:userInfo:] + 88
10  AppKit                               0x19941223c -[NSApplication finishLaunching] + 248
11  AppKit                               0x199411f1c -[NSApplication run] + 252
12  AppKit                               0x1993e9240 NSApplicationMain + 880
13  dyld                                 0x195757154 start + 2476
I'm running a Mac Studio, Mac OS 14.6.
Earlier versions of EOS Utility, running under Mac OS 14.5 and now 14.6 cannot "see" a connected camera. I have a workaround using Apple's Image Capture, but it's a kludge and tedious, requiring three steps to get meaningfully named photos from the camera to the catalog. When EOS Utility worked, it was a single step.
Does anyone have any better experience, a better workaround or any idea whether Canon is working on the problem?
Thanks.
Jim DeWitt
Frozen Feather Images
13 REPLIES 13
A good suggestion. I downloaded AppCleaner, installed it and used it to remove my last version of EOS Utility, 3.18.11, I believe. I downloaded a fresh copy of the eum3.18.5-installer. I dragged the installer to my desktop. And it crashed about 20% of the way through installation, as shown by the progress bar, just as before.
Apple's Image Capture is working as a partial replacement, but I miss the additional features of EOS Utility.
paul-bklyn
I am having what I think is the exact same problem. Installer crashes before ever asking for permission. I'm using Mac OS Sequoia, though when I go to Canon's download page for the EOS R, it says an older OS is detected. I choose the correct one.
I was trying to reinstall this utility because plugging my camera in to my laptop wasn't doing anything and I think the utility is supposed to launch by itself when I connect. I tried also connecting before starting the computer. Maybe I was doing it wrong but it's too late to adjust that because I did have the uninstall program for this utility and it did work, so now I don't have EOS utility and I can't install it.
esimple
I've exactly the same problem. Macbook Pro 14" M2 Max with Tahoe 26. I'm not able to install the app because it crashes during the extracting process.
I just tried to install latest version 3.16.11 on MacBook Air M2 with Tahoe. Installer executed fine. Returned an Already Installed message since it was installed previously.
