EOS Rebel T7 Can't connect the camera to Wi-Fi
Bgreenfield1988
I just got a Rebel T7 and this is my first camera. I am trying to connect the camera to my wifi. I have registered and unregistered and registered again and again. I have changed my phone name... etc. I keep getting error messages that "Connection target not found." When I go back in to register my phone I cannot go forward and it keeps asking me to register my camera. Aargh!
3 REPLIES 3
Hazel_T
Hi Bgreenfield1988,
I'm sorry to hear your phone and camera aren't connecting. It would be good to double check the order of steps you are using to connect the devices. Sometimes if part of the set up is done out of order it can cause connection issues. Try these steps:
1) First the Canon Camera Connect App should be installed on the phone. Once installed don't open it or have it running in the background, we just need it installed at this point.
2) On the camera press the menu button and go to the third yellow wrench tab and select Wi-Fi Function.
3) Next choose Connect to Smartphone.
4) Now select Easy Connection and hit okay. Now the camera should be showing an SSID and an Encryption Key. Leave that screen on the camera.
5) On your smartphone pull up nearby wifi networks, you'll see one that matches the SSID listed on the camera. Select that and when it asks for a password enter the Encryption Key listed on the back of the camera.
6) Once the phone is on the network open the Canon Camera Connect app. Once the app is open in the top left will be a camera icon with a plus sign. Touch that icon, select your camera model, choose Wi-Fi Connection, put a check mark next to “Camera is now ready to connect”, and touch Next. On the next screen the app will detect the camera and show a pop up showing it detected the camera.
7) In the prompt select the name of the camera and now on the back of the camera it will ask if you want to connect to the smart phone. Select Okay and the connection will be established.
alpg49
Enthusiast
Yes, I read the manual and saw all the videos of it >working<.  It simply refuses to connect.  2 cameras: EOS Rebel T7 and PowerShot SX530 HS.  Two android devices running current CameraConnect apps.  Both work great with Camera Access Point WIFI but neither works ("Waiting to Connect" forever) when I try to connect via my home WIFI.  Which of the following should I investigate:  Security options for the WIFI network?  Possible Antivirus on the androids?  (The Norton VPN isn't on, and I even temporarily disabled the Norton Antivirus.)  Is there anything else that will block the connection?  Some have suggested that I just use the Camera Access Point WIFI or the USB cable, but if I really wanted to do that, I'd get a camera with all the inoperative options removed.
I found that if I disable all security options for my home WIFI, the cameras connect seamlessly via WIFI.  This is obviously not a permanent solution.  One thing I found promising (in a way) was that at one point, a window opened asking which camera I wanted to connect.  It showed the T7, but it disappeared in an instant.  Apparently, a security measure blocked the connection.  How do I fix it?  I can get you all the software and OS versions if you want.
