08-02-2024 07:38 AM
I have reviewed what I thought were the relevant sections of the DPP manual, but I must be missing this. I intentionally shoot in RAW and JPEG to see what this actually MEANS, and when I transferred photos to my PC to edit with DPP, all I saw were the images in JPEG format. Did I do something wrong in the transfer? The photos on my Canon camera screen clear show them as JPEG and RAW.
It seems I am constantly going down rabbit holes...
08-02-2024 11:26 AM
Ok. I am the problem. Had two files set up - one with early only jpegs (did not figure out shooting in both early on) and then a second file for a painter friend of mine to use for her work. I was pulling from the jpeg ONLY file and did not realize what the RAW extension was in the other file. Thanks for the help
08-02-2024 10:21 AM
Welcome.
Look in the folder that you that you downloaded the images into. Do you see groups of files with the same name but .jpg on one and .CR3 on the other?
08-02-2024 10:26 AM
Yes, i see the CR3 on my pc in the folder but and i now see the second jpeg in that folder - same number - but not why DpP pick up the RAW one!?
08-02-2024 10:35 AM
If you don't have this option checked (see photo) the DPP will list all the JPEGs together and then all the RAW.
If you select the option it will list both versions of the same file together.
08-02-2024 11:15 AM
I will look for this option now!
08-02-2024 11:26 AM
