EOS R5 Mark II Firmware v1.0.2
This download is available through the Canon Connect App, or directly from the Canon USA Website.
https://www.usa.canon.com/support/p/eos-r5-mark-ii#idReference=software-drivers
  1. Incorporates support for frame rates of 23.98fps/24.00fps when using the LP-E6NH and LP-E6N battery.
  2. The Wi-Fi connection status is now identifiable by the color of the [FTP Transfer Icon].
  3. Adds [Protect Images] and [Rating] during FTP Transfer.
  4. Adds the ability to change [Custom Shooting Mode] while writing images to the media (BUSY).
  5. Fixes an issue in which the camera may become inoperable if a lens that does not communicate with the camera is attached when repeatedly shooting while using HDMI output.
  6. Fixes an issue in which the camera may become inoperable if an image is cropped while other images are being transferred to an FTP server.
  7. Fixes an issue in which Err70 may occur when using an application software such as Camera Connect, and the load on the smartphone increases.
  8. Fixes an issue in which image stabilization may become unstable in movie mode when panning diagonally while using some stabilization rigs (such as monopod or handheld rigs).
  9. Fixes an issue in which all images may not be copied when copying multiple selected images in the camera.
  10. Fixes an issue in which another manufacturer devices (such as strobe or remote camera trigger) may work during pre-continuous shooting.
  11. Fixes an issue that may, immediately after shooting, cause the screen to take a long time to turn off when using a button that has been assigned the “Screen off” function.
  12. Fixes an issue in which Look File settings may apply to multiple custom picture files.
  13. Fixes an issue in which the AF frame movement may not be smooth when several shooting information items are displayed and the multi-controller is operated.
  14. Implements a fix to include custom pictures when saving camera settings.
  15. Improves operation stability during network communication.
I had the same issue. Remove one of the memory cards.
16 REPLIES 16
fsobottka
I installed the new firmware and tried using LP-E6NH batteries in my battery grip.  When powering up, I get the censor cleaning message, then a black screen.  It doesn't look like the update fixed the battery issue for me.
rodc
Has this been pulled from Canon USA as no longer visible?
Interesting that you brought this up. The firmware was initially released on the Canon Hong Kong website and through Canon connect... It was then made available on the Canon USA website.  However, I don't see it there now.  It is still available on the Canon Hong Kong website however.
https://hk.canon/en/support/0401013802
I'm checking to see if it's been pulled or if anybody's talking about it.
It's there now (12/7/24) Canon U.S.A.
Just a reminder - Don't forget to pick up the latest manual 🙂
Newton
Odd, I'm unable to find it on 12/08/24
Past Gear:
1DX, 1DXII, 1DIV, 7D, EF 2.8 Trinity, EF-500mm f/4L IS USM, EF 50mm f/1,2L II USM
Current Gear:
R5C, R5M2, RF15-35mm f/2.8L IS USM, RF24-105mm f/2.8L IS USM Z, RF70-200mm f/2.8L IS USM Z, RF24-105mm f/4L IS USM, RF50mm f/1.2L USM, RF35mm f/1.4L VCM, RF100mm f/2.8L IS Macro USM, 4x 600EX-II-RT Speedlites, 2x EL-5 Speedlites, 1x EL-1 Speedlite
Andy-WV
The 1.0.2 firmware update was pushed to me via the Camera Connect app but would not install (get "Failed to transfer the firmware." message).  I just tried to find V1.0.2 on the R5 Mark ii downloads page but couldn't find either.
Correct, it isn't there (12/10/24). I downloaded it from the Canon U.S.A. support site for the R5 II on the date I indicated in my previous post. Now it's mysteriously unavailable. IIRC, fw 1.8.0 for the R5 was quickly pulled and replaced with 1.8.1. Who knows what they are up to? 🤔
I have it in my downloads directory, but haven't installed it. I always wait a while to update, especially if the fw doesn't correct or add anything that I'm concerned with.
Newton
Hi chrishoesel,
I double checked the product page for the EOS R5 Mark II and the firmware is listed. The firmware can be downloaded HERE. Once you are on the web page click on the Software & Drivers button and it is listed in the recommended section.
If you still aren't seeing the firmware download it would be good to double check the device you are viewing the page on. The website automatically detects the operating system of the device you view the web page on, and if the device can't do the firmware update it wouldn't be listed. We would recommend viewing the page on a Windows or Apple computer with more recent operating systems.
The Hong Kong file refused to install since the camera issued an error that said the Firmware update 1.0.2 (from the Hong Kong site listed above) was older than the firmware on the camera (1.0.1)
No big deal.  Now I see that it is listed on 12/12/2024 in the USA products page.
Past Gear:
Current Gear:
