EOS R10s won't connect to one computer via USB, OK on other computer
orsun6
I have two R 10's.  I connected them to my identical computers via USB cable.  Both worked fine.  Until one stopped.  Both cameras work well with one computer.  On the other, neither camera will connect to EOS Utility via USB cable .  Both connect via WIFI.  The computer recognizes the cameras.  The Utility program does not.  I have traded cables.  Changed USB ports. And I have uninstalled and reinstalled the Utility software.  I have run out of ideas.
4 REPLIES 4
orsun6
OH, Windows 11.
NatalyaP
Greetings orsun6,
I am sorry to hear that one of your two EOS R10 cameras is not working well, and we appreciate the thorough description you have provided regarding the troubleshooting steps you have taken. Per your description, it appears that there may be a possible issue with the USB port of the camera itself since you have swapped cables and the other camera appears to be working well.
We would suggest on sending the EOS R10 camera to our facility for repair.
Items purchased directly from Canon USA or from an Authorized Canon Dealer do include a one-year warranty if the item was purchased less than a year ago. You may view a list of Authorized Canon Dealers by clicking on the following link. I would recommend including a copy of your Proof of Purchase when sending in your item for the facility to review for any in-warranty service or repair.
https://www.usa.canon.com/internet/portal/us/home/contactus/where-to-buy/authorized-dealers
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
orsun6
Since the camera works fine on the other computer I don't think it is the camera. And since the computer recognizes the camera for other programs I think it must be the Utility software.  I have uninstalled it and reinstalled it to no avail.
“ Since the camera works fine on the other computer I don't think it is the camera. And since the computer recognizes the camera for other programs I think it must be the Utility software.  I have uninstalled it and reinstalled it to no avail. “
The camera can communicate with only one app at a time.  Only one of the apps can be running, because one app can block the others from accessing the camera.
