EOS R Firmware update error
niimantse7
I've been trying to update my EOS R to the latest version (1.8) but the update process always stops at 81%. Any help please
#firmware #eos
10 REPLIES 10
NatalyaP
Greetings niimantse7,
Let's remove any accessory that may be attached to the camera. For example, remove the lens, any flash that is mounted to the hot shoe, any cables or cords, and to remove the battery grip if one is installed.
I would also recommend using a memory card that is 64GB or lower, and leave the second card slot empty when updating the firmware on the camera.
If you continue to experience issues, then you may send the camera to our facility to have the firmware updated. Simply log on to your My Canon Account and submit a service request to begin the process.
I checked FW updates for the EOS R
Canon Support for EOS R | Canon U.S.A., Inc.
Did you have the opportunity to try NatalyaP's suggestions?
Start here:
Freshly charged battery (Canon Brand) OEM battery
Remove the lens and all accessories connected to the camera, lens, lens adapter (if used) etc.
Confirm your SD card is full size, not micro SD with adapter
Reset your camera's settings Main and Custom to defaults (Don't skip this step)
Format your SD card in Camera - (since you are having issues) Perform a Low Level Format
Copy the 1.8.0.FIR file to the root of the card
Perform the update steps again.  Post your results.
If the process fails again, try with a different card.
If this fails, your camera will require service from Canon.
Tried all these already🥲 And 3 different memory cards lower than 64. Always stops at 81.
If you've followed all recommended procedures, sending it in for the firmware update would be the next step. You can get started at https://Canon.us/account
Yeah I tried those steps. I'm unable to reset settings because the camera is stuck at the update error
Oh, also, have you re-downloaded the file? The firmware image may have gotten corrupt somehow during download or transfer to the card.
I would re-download the file. If you copied it to an SD card reader that connects by USB, you might try a different cable/port on your computer.
I should have realized that "stops" at 81% = "stuck" in the firmware update operation as you revealed later.
You can try Stephen's suggestion with a fresh download of the firmware, but this behavior is 100% indicative of a bricked device.  So (unfortunately)  ☹️ I suspect the camera will be going to Canon.
I've done some shady stuff with my older camera and never bricked it, so I sincerely hope that's not the case! Usually, if something causes the firmware to fail, the camera reverts to the previously installed firmware.
Just did this but it did not work. Is there a way to reset it at this point?
Really frustrated now🥹
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
