11-09-2022
04:38 PM
09:00 AM
Camera: Canon 5D IV
Hello, I have recently started recording in 4K (4096x2160 - 29.97 fps - MOV)
I noticed that I can't import it to my PC when the videos get longer, 20 sec videos work fine. But anything above that it just won't show up when I try to import it to Windows
They run fine on my camera, I can replay them etc. They just show up as "0 bytes" on my PC
What can I do?
11-09-2022 06:09 PM
Hi MajaT,
I'm sorry to hear you're having issues with importing your 4K videos. Since they playback correctly on the camera itself that indicates the camera and memory card are working correctly. Typically if the file was getting corrupted when it was getting saved it wouldn't playback on the camera either.
Since this is happening when you try to import the videos that indicates there may be an issue with the import method you were using. We would recommend trying a different import method. So if you were using a card reader try importing directly from the camera or vice versa.
One import software to import directly from the camera one to try is our EOS Utility. If you need that software it is available HERE. Once you are on the web page click on the Software & Drivers button and the current version is EOS Utility 3.16.0 for Windows. Once that is installed open the software and you will see a black window with camera and computer icons in it. When you see that window connect the camera and computer with a USB cable and once the EOS Utility recognizes the camera it will automatically refresh to give you the import options.
11-09-2022 06:09 PM
Hi MajaT,
11-09-2022 07:58 PM
Movie file sizes on the 5D IV can get very large. I wonder if this is a case where the longer videos are larger than 2 GB (or 4 GB). What specific OS are you using on your Windows PC? And do you know the format of the drive on your PC you're attempting to copy the movies to? FAT32? exFAT?
11-10-2022 11:56 AM
You are an angel! Thank you so much, that worked perfectly!
