DPP renaming tool not working in macOS 15
Hummel
Dear all
I am using DPP at its latest version (4.19.10.0) under MAC OS 15.0.1.
When I open files (.cr3) in DPP, mark them all and open the renaming tool, it won't start (the renaming tool). You can shortly see the window of that tool, but it disappears right away. Does anyone have the same issue or will it work using DPP4 and Sequoia? It did work with the OS before and the version of DPP before the one I use now. I updated both at the same time.
Any idea anyone?
I use a MacBook Pro M2 14'' (2023), 32 GB.
13 REPLIES 13
You can simply tap the link I provided above. It contains the current version of DPP (4.19.31).
Hummel
Thanks. It works fine now, even though it does not call out that it works using OS 15. But works fine with OS 15.
Oops! You're right! It looks like "they" haven't updated the supported OSes section on that page yet! 🙈
BeesKnees
I had the same issue. Downloaded and installed DPP (4.19.31) as suggested above and now rename tool works as before.
