10-07-2024
06:03 AM
09:29 AM
Dear all
I am using DPP at its latest version (4.19.10.0) under MAC OS 15.0.1.
When I open files (.cr3) in DPP, mark them all and open the renaming tool, it won't start (the renaming tool). You can shortly see the window of that tool, but it disappears right away. Does anyone have the same issue or will it work using DPP4 and Sequoia? It did work with the OS before and the version of DPP before the one I use now. I updated both at the same time.
Any idea anyone?
I use a MacBook Pro M2 14'' (2023), 32 GB.
10-22-2024 08:19 AM
10-23-2024 03:49 AM
Thanks. It works fine now, even though it does not call out that it works using OS 15. But works fine with OS 15.
10-23-2024 08:21 AM
Oops! You're right! It looks like "they" haven't updated the supported OSes section on that page yet! 🙈
11-24-2024 11:10 AM
I had the same issue. Downloaded and installed DPP (4.19.31) as suggested above and now rename tool works as before.
