10-13-2017 02:50 PM
Hello .
I will make it short.
When I look in DPP, the microadjustement announce for one picture is+52 microadjustement !!
What I am really surpised , it is because my camera body (1Dx), allows me to microadjust only between -20 and +20... So How can I have a +52 value ?
I just try to set-up my camera micro-adjustement correction to -20, 0, and +20. And DDP show me, as espectd, -20, 0 and +20.
The shoot was taken a week ago. In beetwen I have worked on the microdjustement of my camera, so I have changed the setings since.
So , any idea how can I have a +52 microd-adjustement ?
I have attached a screen-shot, it's in French but the words are almost the same, So I guess I won't be a pb 😛
10-13-2017 02:53 PM
Could be that the factory has more range, and you are oly allowed +/- 20 above that.
10-13-2017 03:07 PM
Thank you Kvbarkley.
I am not sure to understand you. (Sorry my english is not super good). What do you means by the "factory" has more range ?
I used this camera and lens for more than 2 years I have never faced any issue before.
The seting of my camera and lens is done by me. All settings are between -20 and +20.....
10-13-2017 04:32 PM
Is it conceivably significant that 52 centimeters is just over 20 inches?
10-13-2017 04:37 PM
Hello Robert,
I am not speaking about 52 centimeters ! :D. I am speaking of 52 unites of mico-adjustement in the micro-adjsutement option of the camera. (52 steps in a ladder who is supposed to go from -20 to +20) .
How can it be possible ??
https://learn.usa.canon.com/app/pdfs/articles/AF_MicroAdjustGuide_desktop.pdf
10-13-2017 05:01 PM
If it is only one file, it could just be a bad bit or two in the file.
10-13-2017 05:19 PM
No , that was for all files during the all day.
The micro adjustement went from +4 (at 70mm -– that was a correct value), to +52 (at 200mm) (that is not a correct value) !!
And I have all the interval value betwen +4 and +52 regarding the interval value of lens mm (from 70 to 200 mm ).
10-13-2017 05:26 PM
@alexandremayeur wrote:Hello Robert,
I understand all that. And I too had regarded the AFMA adjustment value as simply a dimensionless number between +20 and -20. However, what you are actually doing is correcting front- or back-focus in the lens, which is, in fact, a measure of distance. And it would be possible, at some chosen standard distance, to measure that correction in either inches or centimeters. If that were, in fact, what was being done, it would not be unimaginable that a version of DPP intended for American users might report that correction in inches, while a version intended for users in France might report it in centimeters. That would, at least, cause the observed evidence to make sense.
Indeed, I don't have time to look right now, but is there an option in DPP to report distances in either English or metric units?
10-13-2017 05:36 PM
You know of course, that we have no connection to Canon - we are just users, and thus, can only guess.
10-13-2017 05:39 PM
Thank you for you answer.
I undestand what you say. But I guess it's not a mistake of the software.
(for you information, there is no option to choose between meter or inch/feet)
Indeed , for all other pictures, all micro-adjustement shown with DPP are well betewenn -20 and +20 (as expected).
This issue happenend only for that day, with this lens.
After that, I have manage to set-up all settings back to zero and it has obviously solved the problem.
But I try to understant how can this +52 value have been put in my camera body ? When the camera menue allegedly allows only number between -20 to +20.
