03-16-2019 10:54 AM
I've been using DPP 4.8.30 with GPU acceleration, have "Use graphics processor for image processing" selected in Preferences\Image Processing 2.
As of 4.9.20, and in 4.10 as well, I do not have that option any longer, "Graphics processor setting" is missing entirely.
If I re-install version 4.8.30 the option comes back.
Using Mac OSX 10.12.6 (Sierra).
Barak.
03-20-2019 10:02 AM - edited 03-20-2019 10:03 AM
I installed a Nvida RTX 2060 to see how it would play with DPP 4.10.01 and it does speed up performance somewhat. There is a check box to use the video card for image processing however there is no check box to use for image preview under preferences, just the line reading image preview but without an available check box.
It is definitely faster when applying digital lens optimizer or changing noise reduction settings with the new card so it is better than my older Nvidia card but I am still confused by the lack of a check box to use for image preview.
The new card has 1,920 "Turing" Cuda cores so it has plenty of video processing power and has 6 gigs of GDDR6 memory on the card. It is sitting in one of the two fast PCI slots reserved for video cards in my dual processor workstation.
Bottom line, DPP 4.10.01 is faster with the new card than with the old but still somewhat slower than 4.9.2 with the old card so hopefully the next update will speed things up. The hardware is there to do more but so far DPP isn't taking advantage of it. Processor load peaks at 10% briefly, GPU load never goes above 5%, system memory sits at 6-7% utilization and it is using 1.1 gigs of the 6 gigs of on board video memory and 0.1 percent of available shared system memory.
Rodger
03-20-2019 01:12 PM - edited 03-20-2019 01:12 PM
Thanks for posting the updates with your experimentation. I still haven't made the jump to DPP 4.10 yet, nor have I found any great deals on graphics cards either. Around here at least the bitcoin clowns don't seem to have gotten the news yet that their bubble has burst.
I'm wondering if there are some newer PC "gaming" motherboards available that have some pumped-up graphics support onboard?
03-20-2019 01:41 PM
You are welcome and hopefully the prices will come down further. I first thought about an upgrade last year and was shocked at graphics card pricing courtesy of the bitcoin bubble.
Some additional points after going through about 150 photos this morning:
1. Digital lens optimization is markedly faster with the new card
2. I have tried using auto gamma and it seems to be happy now that the new card is installed. No out-of-memory errors and results are fast. I also note that before when auto gamma was working I would see numerous changes as it worked through the process. Now I see one shift to the original image and the next shift is final correction and the entire process is usually about 2 or 3 seconds now.
3. Convert and save of a full 1DX 2 image into a high res jpg takes about 10 seconds which may be slightly faster.
4. Corel video studio ultimate provides much faster final video rendering with the new card and it provides the sort of dramatic difference I was hoping to see in DPP. Resource utilization is a little higher than in DPP. That will be nice for some video I will be shooting later in the season.
The new video card runs very cool which makes sense for what is supposed to be a gaming card being used in a pretty easy life. CPU and GPU temperature don't budge above their mid 30C idle rate in DPP and climb to and stabilize in the upper 40C range during an extended video rendering.
The gaming motherboards might be a great idea since I don't think the bitcoin miners ever took that route to getting more processors. I suspect you might also find some good deals on used video cards as some of the bitcoin miners have gone broke but those cards likely have some hard hours on them running at maximum performance.
Rodger
