07-23-2022 09:59 AM
Hello Community,
I'm using DPP 4.0 and the "Show Second Screen" feature by right-clicking on the image I'm working on and seeing a second image. The trouble is, my second photo is showing up off the monitor and I can't find it. I know this because the photos were progressively being placed to the right, and then it was only a line visible and I wasn't able to maximize it, and now they don't show up at all. I can't find a toggle or anything to locate it.
I'm sure there's a very easy solution, I just haven't been able to find it. Windows 11, Laptop and additional monitor setup. Thanks for any ideas.
Stephan
07-23-2022 10:15 AM
There are a few solutions depending on your hardware, but the easiest would be to change your screen resolution until you can grab a corner, etc and drag it back into view.
07-23-2022 10:15 AM
07-23-2022 10:22 AM
Maybe its the second monitor or W11 issue? Try disconnecting the second monitor first and see what happens.
07-23-2022 10:58 AM
That seems to work. I changed from 125% to 175% and it showed up. Then I backed it down again. Thanks!
07-23-2022 03:48 PM
There are several keystroke combinations that can move off screen windows, alt-shift-m. Which one keystroke combination is best to use depends upon the type of window that has gone missing. Is it the main app, or a dialog window for the main app?
