DDP4 Edit saving issues - losing some edits on reopening program.
nelsonsdavis
Hello everyone. I'm using the lastest version of DDP4.
I've never had this issue before, but now it occurs regularly and I'm going bonkers.
I am editing RAW photos. Make the edits, save all succesfully. Close DDP4.
Open DDP4, go back to editing and I see nearly half or more of my edited raw pics have reverted to their previous edited state. Example, using brightness adjustment - brighten up may pics, save, close, Open program and the brightness adjustment setting for those pics is back to 0.00.
Redo the brightness for all affected edited pics, close, open. All is fine. Continue editing other pics, save, close (am not converting yet to jpeg, just saving the raw files with the edits). Open the program, again, some pics have lost the edits. Manily to do with the brightness adjustment. However, other times, looking at those same edited raw files, now the brightness for the picture is way to bright, but the setting shows 0.00. For what it's worth, the version I am using is 4.5.0.0. BUT, I had the same issue with the prevouis version.
The only thing that has changed in my PC system, is I used Spyder 4 pro to calibrate my three monitors. I only do the edits on one of the monitors.
Anyone have a clue what's going on? I am using windows 10 pro 64bit.
8 REPLIES 8
diverhank
I don't use DPP so I am no expert but as far as I know, DPP does not save your changes to the RAW files anywhere.  You need to save your file as one of the available formats then the changes are saved.  This is one of the reasons I use Adobe RAW where it saves the changes in an XML file.
Diverhank's photos on Flickr
Thanks for that info. But, I've been using DPP3 and 4 for the last 2 years. I've never experienced this issue before. Edit in raw, save in raw, close program, open those same edit raw files and they've always remained "as is" from the last edit. So, I dumbfounded. I just edited 228 RAW files, saved them, but have not closed the program. Doing a batch convert to jpeg - viewing them in Picasa as they get converted. They look fine. But, I have a feeling once I close DDP4 and restart the program, there will again be some issues.
Perhaps now is a good time to fire up lightroom and teach myself how to use it.........
I've been using DPP for nine years, and I've never had anything like that happen. I have had DPP4 crash and lose my edits, so I've gotten in the habit of saving each picture after I edit it. The asterisk in the frame tells you when an image has not been saved.
The only thing I can think of is that you may have inadvertently screwed up some default setting that is causing the files to be saved somewhere else. Also, DPP4 is a serious resource hog, so trying to do too much at once may be a problem. I guess I'd start by doing individual saves, and if that doesn't cure the problem, try uninstalling and reinstalling. I believe that when you uninstall, it asks whether you want to flush your settings; doing so may be a good idea.
Bob
TTMartin
The little 'Save' button at the top of the screen, is actually an 'Export to JPG/TIFF/etc' button. To actually Save your edits use the 'File' 'Save' choices in the menu or type '<ctrl> S'.
DPP 4 saves your edits as flags in the CR2 file, though you can always choose to revert back to the original as shot settings at anytime.
Yeah, the ambiguity of the "Save" command is inexcusable. Just one of several glitches introduced in Version 4 that they obviously have no intention of fixing.
Bob
Do you get this window when ypu go to exit DPP?
Select "Yes" or "Yes to all" and the edits are saved so that when you re-open the file the edits are there.
You should get that dialog box whenever you exit "Edit" mode, and you have unsaved edits.
jrhoffman75
That is correct.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
