Creating an equirectangular image of a still in Canon VR Utility
NewToThis54321
This seems like it's a basic question, but I can't figure it out. I'm trying to convert a still image taken with Canon's 3.9mm Dual fisheye lens to an equirectangular image using the VR utility. The instructions make it seem like this process should happen automatically once the image is imported. Or am I missing something?
Nevermind. I discovered that apparently this is how equirectangual images are rendered with the 3.9mm lens (144°)... https://postperspective.com/editing-vr180-content-from-canons-eos-r7-part-2/
I imported the this file from EOS utility to Premier Pro, then exported it from APP with VR settings. It shows as it's supposed to when viewed in the Pigasus app on Quest.
4 REPLIES 4
John_Q
Hello NewToThis54321,
Let's check to see that when the clips/stills are imported that you have selected [Equirectangular Projection] in the Preview Settings. Clips are corrected when [Equirectangular Projection] is selected.
Okay. So another basic question, where are the Preview settings? I see no such settings, and no such option to select Equirectangular Projection anywhere. I can check and uncheck Fisheye view in the preview window. Is that what you're talking about? If so, as you can see in the screenshot Fisheye view is unchecked. It changes the image from a perfect circle to what you see there. That's not how I'm used to equirectangular images looking.
Thank you for the feedback! I'm happy to hear that all is well. Thanks for the link too.
Holiday
