Converting Hif to Jpeg on computer
BreegeEnglish
I somehow today saved about 300 photos in HIF.  I've never done that before.  would anyone know how to convert HIF to Jpeg on a computer.  Very frustrated
17 REPLIES 17
rs-eos
Do you mean HEIC or HEIF?
Are you using a Macintosh?  If so, you can use Finder Quick Actions to perform the conversion:
  1. Select all the HEIC or HEIF you wish to convert
  2. Right-click or Control-click the selected items
  3. Choose Quick Actions > Convert Image
  4. In the Conversion options, choose JPEG
Ricky
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, we will need to know what model Canon equipment you are using and which operating system. Error messages? Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
johnrmoyer
The Canon DPP software will do the conversion if they were produced by a Canon camera. DPP is free to download from the Canon support page for your camera if your camera is a Canon.
The Apple Photos.app included with macOS will do the conversion.
If your camera also saved a raw file, Canon DPP will convert the raw file to JPEG.
ImageMagick might do the conversion depending upon which libraries were included when it was built.
Some versions of gimp free software will do the conversion.
Some Canon cameras will do the conversion. It is in the playback menus of the camera.
I usually work in RAW and then convert to jpeg, depending on what the image is.  I can't get DPP4 to convert for me.  I've been trying that.  I also tried to upload an image here and it wouldn't take it.
Did you ever find a solution for this? im having the same issue and i dont think i have the knowledge to fix it
You need to answer the same questions we posed the OP.
Did you try any of the solutions already presented?
The first thing you need to do is go into the "Shooting 2" menu and disable "HDR Shooting - HDR PQ". Shooting 2 is where it is in all of the R manuals I have, so I'm confident you will find it there even though you didn't mention which R you own. This will prevent the HIF files from being created in the first place. Next you need to download/install DPP 4 and get acquainted with the "Batch Process..." command in the File pulldown. You will have to have your HIF files loaded and selected in DPP. I've used other converters and DPP, albeit slower, does the best job.
Depending on how many HIF files you have, it may take some time. When I use HDR PQ, I don't save to HIF in camera but convert to HIF in DPP after editing my Raw files. So my conversion is from Raw. The screen shot was from another post about HIF to JPG that I posted.
Newton
CaptnBob
I've used this method (Batch save and Convert) to convert HDR photos to JPG, but they all end up much lighter than the original, both viewed in DPP. The exported JPG looks the same in DPP, ACDSee and Windows 11 Photo viewer. I have tried selecting the option to "Embed color profile" and not embedded it. Both results are the same.
To get the resulting JPG to look anything like the original on the same HDR monitor, I have to edit the JPG and reduce the brightness -30eV points.
I cannot find a way to fix this in DPP.
I can also not edit the HDR photo. All the brightness and colour settings are greyed out on the "Tool palette". I have DPP 4.19
Can anyone help please?
CaptnBob
Further to the comment above, the conversion applies some sharpening as well.
There is no control over these items (that I can find). The same changes appear when using the in-camera HIF-> JPG conversion.
I have a Canon R7.
