Color profile options vary by image in Lightroom
Tiffanyl2121
Hi, So I bought a new camera (Canon EOS R) and I absolutely love it but I am having issues with Ligthroom and the Color profiles. I shoot in RAW so when Import images from the SD drive in Lightroom some of my images give me Adobe Profiles (Adobe Color, Adobe Vivid, Etc) and some of the images just say color and doesn't give me an option to change. How can I get all of my images to come up with the different color profiles.. What am I doing wrong? It makes it impossible to edit and turns their faces red. It looks like some of the images are not RAW even though the settings in my camera are set to only RAW. It is making editing impossible and I need help66898841538__CBBF9FBA-396E-4550-9254-76A2549D5D18.jpg
jrhoffman75
Lightroom will not automatically convert RAW files to JPEG, but under some conditions the Apple Photos app will. Something to do with Optimized Storage settings.
Since you are using Lightroom I recommend you not use the Photos app. Import your files into a folder using Image capture and then import into Lightroom.
9 REPLIES 9
Tronhard
VIP
VIP
You might be better advised to post this in a forum for Lightroom.  This site is for people having issues with Canon hardware and software, rather than other products. 🙂
cheers, TREVOR
Tiffanyl2121
I'm having an issue with the camera EOS R. I have the settings to be RAW but when I upload on the Mac and then pick which ones I want out in photos and then import into lightroom. Some of them are converted into JPEG and some of them stay RAW. How can I prevent them from doing this in the future? It makes it very hard to edit. I would like them to stay RAW
Tronhard
VIP
VIP
Again, this sounds like an issue with Lightroom, rather than Canon. Have you had this issue with files from other cameras?
Much depends on what version of Lightroom you have.  I use the CC versions of Lightroom, Bridge and Photoshop under Windows 10, and have absolutely no issues with importing and manipulating images.  Lightroom should not be changing the original versions of your file formats, but most likely it will save as another format.  I would recommend  You need to make sure your software is up to date and have the latest drivers.  Again, I would post this on a Lightroom forum or for Adobe support
cheers, TREVOR
jrhoffman75
That was the exact issue too! Thank you for your response. I can breathe a little easier 🙂
ebiggs1
"What am I doing wrong?"
To expand a bit on what John Hoffman said, when you use Lightroom it is ALWAYS best to let LR do all your file transferring or copying or moving of files, whatever. Never use any other app. LR needs to know what is going on and if you use any method of file maintenance outside of LR it does not know that happened. All your files should show as CR3 in LR.
Different software can interpret colors slightly differently, so custom profiles help keep things consistent. Some people tweak profiles manually to get colors just right for their specific needs.
MariaKaterin
If you're handling large photo libraries, digital asset management software with ai-based search helps speed things up. It makes locating specific shots easier by tagging and organizing images automatically. If you’re switching between Canon software and Lightroom, color variations can be frustrating, especially if profiles don’t match. Using Canon’s own profiles where possible helps keep colors consistent across different programs.
ebiggs1
You know this is a 3 year old thread. I doubt the OP is still around.
